My push-To-Talk don’t work in TS3! I just try everything, but i can not even put a key! It just won’t, as if I’m not squeezing anything! (Note: the key works perfectly, and “Voice detection” too)
Whispers don’t work either
That’s not much detail anyone can work with.
Gamepad and Joystick Hotkey Support
plugin installed and activated?If the answer to last 2 questions is a YES and your device is a Joystick or Steering wheel then i can only say that the plugin is not working perfectly with these devices.
A post was merged into an existing topic: Trying to set hotkey to game controller
