Help! Removed Grant and Can't change the order of Server Group Icons... :(
It should not look like this! It should have a value of 75 max and not above!
Just showing him where it is, I took this as an example from “Admin Server Query”
ok thx for help
and exist way block use whisper for some groupe ?
All server groups that may be whispered to by a particular server group must have a value of i_client_needed_whisper_power less than the whispering server group’s value at i_client_whisper_power.
If a server group should not be whispered, it must either have a higher value of i_client_needed_whisper_power than the i_client_whisper_power of the other server groups or if it should not be whispered at all, the value of the permission i_client_needed_whisper_power must be set to 76 to exceed the maximum incoming whisper power of all groups and it will ignore it.
