Purchased a new headset and now whenever I start up TS I can hear myself even if PTT is on. Scoured the internet for fixes and nothing is working. Used teamspeak for over 6 years now and never had any problems like this before
Hi, first of all do you hear yourself in Windows? you can check this by opening the sound settings → choosing your microphone and “use this device as a playback source” in the second tab, is this active?
What should I do if I connect my Logitech Wireless headphones and I hear myself, everything that can listen to the microphone is turned on. This doesn’t happen with other headphones, only with these ones. Please help.
This is a setting in the Logitech G Hub and not Teamspeak.
You need to lower the Sidetone value to 0.
Manetti ist raus ![]()
Thank you very much, I just noticed this setting)
