Hey guys, I installed Fedora Server on a mini pc today I wanted to install ts3 server on it.
The server works when starting with ./ts3server_startscript.sh start but i’m stuck at making the service work. here is my service:
Unit]
Description=TeamSpeak3 Server
Wants=network-online.target
After=syslog.target network.target local-fs.target
[Service]
WorkingDirectory=/opt/teamspeak
User=teamspeak
Group=teamspeak
Type=simple
Restart=always
ExecStart=/bin/bash /opt/teamspeak/ts3server_startscript.sh start
ExecStop=/bin/bash /opt/teamspeak/ts3server_startscript.sh stop
[Install]
WantedBy=multi-user.target
I have found parts of it online, and I also used DeepSeek to help but when i start the service, this is the result of systemctl status teamspeak:
× teamspeak.service - TeamSpeak3 Server
Loaded: loaded (/usr/lib/systemd/system/teamspeak.service; disabled; preset: disabled)
Drop-In: /usr/lib/systemd/system/service.d
└─10-timeout-abort.conf, 50-keep-warm.conf
Active: failed (Result: start-limit-hit) since Thu 2025-02-06 19:32:41 CET; 1s ago
Duration: 60ms
Invocation: 50ed9a7953f34055980012564d67c910
Process: 3120 ExecStart=/bin/bash /opt/teamspeak/ts3server_startscript.sh start (code=exited, status=0/SUCCESS)
Process: 3130 ExecStop=/bin/bash /opt/teamspeak/ts3server_startscript.sh stop (code=exited, status=0/SUCCESS)
Main PID: 3120 (code=exited, status=0/SUCCESS)
Feb 06 19:32:41 s920 systemd[1]: teamspeak.service: Scheduled restart job, restart counter is at 5.
Feb 06 19:32:41 s920 systemd[1]: teamspeak.service: Start request repeated too quickly.
Feb 06 19:32:41 s920 systemd[1]: teamspeak.service: Failed with result 'start-limit-hit'.
Feb 06 19:32:41 s920 systemd[1]: Failed to start teamspeak.service - TeamSpeak3 Server.
Thanks for any help!
gabors0:
This is the service file I’m using, you should be able to adjust it to your needs.
[Unit]
Description=TeamSpeak 3 Server
Documentation=http://www.teamspeak.com/?page=literature
Requires=mysql.service
After=network.target
After=mysql.service
[Service]
User=ts3
UMask=0027
WorkingDirectory=/home/ts3/teamspeak3-server_linux_amd64
ExecStart=/home/ts3/teamspeak3-server_linux_amd64/ts3server inifile=/home/ts3/teamspeak3-server_linux_amd64/ts3server.ini
Restart=on-failure
[Install]
gabors0
February 9, 2025, 12:30pm
Thanks but it still can’t start. Can I ask where is the service file you’re editing? I edit mine with sudo nano /lib/systemd/system/teamspeak.service but I remember there being another path
wulcato
February 9, 2025, 12:52pm
[Service]
WorkingDirectory=/home/wulcato/wulcity/teamspeak
ExecStart=/home/wulcato/wulcity/teamspeak/ts3server_startscript.sh start
Restart=on-failure
[Install]
My service file is like this.
Edit = You can also make it run continuously as a cronjob.
Laudian
February 10, 2025, 5:20pm
User defined service files should be put in /etc/systemd/system, though I don’t believe that should cause the problem that you see.
What exactly are you using now, and what error do you see?
sxseth
February 10, 2025, 7:08pm
6
systemctl stop teamspeak
systemctl disable teamspeak
rm /usr/lib/systemd/system/teamspeak.service
vi /etc/systemd/system/teamspeak.service
[Unit]
[Service]
User=teamspeak
ExecStart=/opt/teamspeak/ts3server_startscript.sh start inifile=ts3server.ini
ExecStop=/opt/teamspeak/s3server_startscript.sh stop
PIDFile=/opt/teamspeak/ts3server.pid
RestartSec=15
Restart=always
[Install]
systemctl daemon-reload
systemctl enable teamspeak
systemctl start teamspeak
gabors0
February 11, 2025, 2:52pm
7
Thanks a lot, this fixed it. Although I still needed to put /bin/bash before the execstart and stop commands. I’m guessing that the fedora cockpit had something to do with that, since I ran all the commands there.
But it works now
gabors0
February 11, 2025, 2:54pm
8
I made it work, using sxseth ’s service, but it was probably the path that was wrong
