Help with MyTeamspeak server tag synchronisation
I need help with MyTeamspeak. I have a MyTeamspeak account set to synchronisation enabled (automatic), yet no server tags are synchronised. I cannot find any other options, and I have not found any help on this forum. Does anyone know how to do this?
check your identities all id is need to be in the synchronised id list and not in the local id list .
check good id is set to default.
check good id is set in bookmarks.
Thanks for the reply!
What do you mean by “good id”?
sorry, i mean the right id what you use on your server
