Horizontal scroll bar in third column
Most of the time there is a horizontal scroll bar in the third column which is not necessary. The Client should adjust the third column size to the size it displays. Currently it has some extra space for what ever reason.
TeamSpeak_cIJSeJRR7Y
Version: 5.0.0-Beta76
Design.
Else then each section would look like it belong to the middle of the client.
But it looks unfinished and I don’t know how a horizontal scrollbar tells the user that it is not part of the middle column?
Talked to Dev.
We need to fix this scrollbar being there. This happened after last CEF update.
SORRY.
Edit
Some dialogs are also effected in beta 74 already.
This will be fixed for next release.
