Nell’ultima versione 3.5 ho riscontrato diversi problemi nella funzione tasti rapidi.
Non riconosce più le perifiche esterne.
1st
I had no luck with google translate but deepl is a really great alternative!
2nd
It should work just fine. Make sure the HotKey plugin is installed and enabled.
Ok sorry for the post in italian.
So , i’ve already controlled that the plugin was installed. I also try to unistall and reinstall it but notihing changes.
So finally i go back to 3.1 and everything works fine
I have tried many times but nothing changes… ![]()
As I said for me it works just fine. Make sure all drivers are installed correctly and are up to date.
I honestly have no idea what could be the problem.
