How can I convert temp Server Groups to permanent?
TY
Add the b_group_is_permanent right to the group.
To find the right one you can use the filter above.
Edit: You can use the Advanced permission system to search the Right.
To do this, go to Settings → Options → Application and click on “Advanced permission system”.
And now you can search for the b_group_is_permanent Right in the Filter. ![]()
Thanks so much, got it.
thank you
Hello everybody,
I’m using TeamSpeak 3 server version 3.3.17 and I created a server permissions group for mods on my server. Everything works fine except that when I’m going to assign that group to a user it says [temp] in the groups list. After I assign the group to the user and he disconnects he loses the moderator group.
Why does the group show as temp and how do I change it?
Thanks on beforehand!
DonK
Hey @DonK_KijotE,
You will find a Solution in this Thread: How can i make a group permanent?
Damn, I was looking for temporary all the time and didn’t find that… My bad.
Thanks for the quick response Rikku, have a nice day!
