hello i would like to know how to enable on TS5 client the possibility to see other users in other rooms, currently with the beta of ts 5 i don’t see users in other rooms
waiting for feedback thank you ^^
TS5 automatically subscribes to all channels after connecting and cannot be done manually. It may be possible that you run into the subscription limit of your server and can therefore not see all channels. So maybe check with the admins of the server how high the limit is set.
