Hey guys,
I run into the problem that my members can’t change the Icon of their own channel.
I approached it like this:
The Channel owner has the “Channel Admin” Channel Group. In there I set the “i_channel_modify_power” to 75 but still if someone wants to change their Icons it still says
“insufficient Permission Modify Power”.
What could be the problem here?
This is the bare minimum for a channel admin as an example to edit their channel icon.
i_permission_modify_powermust have at least a value of 1. -
i_icon_id
Grant value must be set here and Grant value needs same number as set ini_permission_modify_power. -
b_icon_manageis enabled.
works like a charm now, thank you very much
