How do i get rid of Pokes?
You can either click the X besides them, or use the arrow below to dismiss all that are currently in view.
Other than that you can not disable them as they are a feature to grab someones attention. In your case it seems to be misused by a Bot. If you are in contact with one of the admins they could adjust your permissions, so that they you won’t receive any further pokes.
