I’ve got TeamSpeak installed on my Fedora 36 KDE system but I couldn’t open any URLs / hyperlinks.
After some googling, it wasn’t clear what the workaround was, but it sounds due to TeamSpeak shipping with its own QT library from the looks of it.
This is what I did to get the links working, it should also work for other KDE distributions.
HowTo
My Temspeak is installed to /opt/teamspeak/
Add the below to the ts3client_runscript.sh under the rest of the exports at the bottom
/opt/teamspeak/ts3client_runscript.sh
export PATH=/opt/teamspeak:$PATH`
Create xdg-open file with below contents in the TS3 /opt/teamspeak/ folder
/opt/teamspeak/xdg-open
#!/bin/sh
# Script by FingerlessGloves
echo "Unsetting LD_LIBRARY_PATH for LINK..."
export -n LD_LIBRARY_PATH
/usr/bin/xdg-open $@
Make the xdg-open executable
chmod +x /opt/teamspeak/xdg-open
To open TeamSpeak run
You should now find URLs open now in your default browser.
Note;
Your original xdg-open could be at a different location to me. Simply do whereis xdg-open in a normal terminal on your system to find where it’s located for you.
