Hello I am running into an issue that hasn’t occurred until today (I’ve rented the server since August). The idle time is short enough were it will kick clients relatively quickly at about 20 seconds. I can’t find pictures or any tutorial that shows me how to change the value and was wondering if some of you could help me.
Use the advanced permissions system.
Then increase the value for the i_client_max_idletime permission
Note: The permission can be set for the server/channel group, the client permissions, the channel permissions or the channel client permissions.
Hello How do I access this advanced permissions system?
Therfore go to Tools -> Options -> Application -> Misc -> Advanced permissions system
in your TS3Client.
