How to create permanent Channels?
Hey there, I just got started with TeamSpeak and decided to pay for the option to establish a community. Now I can see the Server I created and clicking on it there is one Channel named “Default Channel”, where all of us can join and talk. Furthermore, I can create an additional channel to have separate voice chats - but those channels are not persistent. As soon as I leave it, the channel is gone. So we have to set it up again and again every time, which is quite annoying. In Discord you can create several voice channels which continue to exist even when no one ist using them. I wonder how I can create persistent / permanent voice channels in TeamSpeak 6. Does anyone know?
You need to make sure that you enable permanent channel, otherwise they’re deleted when leaving.
This Option is missing when I create a new channel, It looks like this:
You are currently missing the permission to create a permanent channel on the server.
Do you still have a menu on top of the server tree that asks for a privilege key?
Yes
Then you’ll need to put the privilege key, you’ll find on the Community dashboard into the menu. After that you’ll be assigned an administrative group and the button should appear.
Ah now I got it, thanks a lot!
