How to recover your privilege key
hi i was editing stuff on my server and somehow lost my privilege key. and don’t know how to get it back.
Generate a new privilege key
  1. Start any telnet client - you can use e.g. PuTTy
  2. Connect to your Teamspeak 3 server IP using Telnet on port 10011
  3. Login using command login serveradmin yOuR_nEwP@ssw0rd password in command is the same as the one you set for your serveradmin previously
  4. Select your Teamspeak server instance (if you have only one just this would be your default: use 1 and hit enter
  5. Now it’s time to generate new privilege key, for that use following command: tokenadd tokentype=0 tokenid1=6 tokenid2=0
  6. That will return you token, which you can copy and paste in Teamspeak 3 client under Permissions > Use Privilege Key
