i downloaded voice mod thinking nothing would change for teamspeak, realizing it was a big mistake. I deleted voice mod from control panel without checking teamspeak because I thought nothing would happen. I open up teamspeak, and i check my playback and capture device. They are selected correctly, but its saying it is invalid. Discord is working perfectly fine with this.
Try to delete voice mod and restart the ts if isnt work then try set the device to default and if it still not working then try uninstall (delete all configuration) and reinstall the ts client.
no worries, i fixed it myself. I already had voicemod deleted at the time. I restarted my pc and teamspeak went back to normal. Thanks anyways.
Im glad to hear that
