how to enable teamspeak 5 to run in parallel with the computer. So when I turn on the computer to open and ts5?
Do you want your client to start automatically when you start your computer (operating system: Windows)?
Go to the client settings -> Behavior -> Applications -> Start with Windows
If there is a function for other operating systems directly in the client settings, I personally don’t know.
thank you i will definitely try
thanks a lot I fixed
@TS.ChrisR can you lock
