I need help with the new client, I can’t change channels with hotkeys since I can’t find the option.
You can help me
You can help me
That is not implemented in TS5 yet, as it is still a Beta and does not feature all advanced Hotkey actions you can do in TS3. If this is important for you, then you need to stay with TS3 for now.
Thanks you, i don´t know it.
I comeback to TS3
