hello community
I wanted to know how to fix the icon in TeamSpeak5…my icon in TeamSpeak3 is perfect but when I open TS5 the icon loses quality and looks ugly…anyone help?
hello community
In what way does it change the quality?
Do you have an example (via screenshot)?
look at the difference
see?
Personally i had this issue between the ts3 computer client and the mobile one.
The fix i found and actually do it with all my icons i do upload them with 32x32 analysis instead of the 16x16 we all know.
I tried that and it didn’t work if I send you the icon, can you edit it for me? pls
Do you have the icon in that size? Send me the image, i will see what i can do.
Can you give a try with this one?
thx for all improved but still blurry
Yea, it’s a bit blurry from the image you gave me. But it was the best i could do with that.
There is an app that you can resize any image you want and it’s really simple to use.
ok friend thx very much
