Icon Suggestion
Suggestions:
  1. Adding the ability for us to upload alt server group icons, having one set of icons for light themes and another set of icons for dark themes.
  2. Removing the hexagon boundary from user uploaded channel icons. (I would like to determine the shape and size of my channels icons.) OR giving us an option to toggle the hexagon channel icon on or off.
i think this is unnecessary
I dont see problem with hexagon icons, but i’m curious about the optimal size for icons (ts5 channel, server groups and it will be the same in the new android app? ) , or still stay 32x32?
You can already use icons much larger than that! You can even use vector graphics so that the icons are always clean no matter what resolution. :slight_smile:
I really like using the svg icons
tnx :smiley:
