I am currently trying to install ts3 on a mac. I issued “touch .ts3server_license_accepted” and the file was written to the folder. When I try to issue “./ts3server” it waits a few seconds and reports Illegal instruction: 4. Does anyone know why this is occuring and more importantly, how to fix it?
My current folder contents:
.DS_Store
libts3db_sqlite3.dylib
redist
CHANGELOG
serverquerydocs
LICENSE
sql
doc
ts3server
libts3_ssh.dylib
tsdns
libts3db_mariadb.dylib
Thanks
Which version of the server and which Mac OS version are you using?
Server - 3.12.1
MacOS - 10.10.5
Mac - Dual Intel Xeon (perhaps the issue?)
You need at least 10.14 with 3.12 - not sure if that’s the problem but it’s one of them.
Loaded just fine on the i7 MacMini running 10.15. Oh well, I was hoping to use the ol’gal for something useful but apparently not for this version. What is the latest version that I could run on that setup and would it be a considerable performance change? Also, would the recent clients apps be compatible?
Thanks for the help!
You might be able to use the Docker version, which would be a ‘better’ solution (not able to test this, though).
