Installation Guide: Setup custom soundpack
Oh, you’re right. After I re-copy the audio file, the custom voice pack took effect. Thank you!!!:sob:
Hello, I know this is probably not at the top of your priority list and you have more important things to do. Nevertheless, I think it’s important. Why can’t the sound pack be switched to Male?
Where do I find this? I installed it via Flatpak and only have something at /var/lib/flatpak/app/com.teamspeak.TeamSpeak. But I cannot find anything there that’d be related voice files as it is on Windows at C:\Users\User\AppData\Local\Programs\TeamSpeak\html\client_ui\sound\default.
I was able to replace the theme at /home/deck/.var/app/com.teamspeak.TeamSpeak/config/TeamSpeak/Default/extensions.
They installation files are on the var drive on the left side of the explorer:
But the sounds are located here:
/var/lib/flatpak/app/com.teamspeak.TeamSpeak/x86_64/stable/6201584b029ea321f0edd516c6bbf0c9b7b0b7930c6ff2c8261ae9438dd4dadb/files/extra/html/client_ui/sound/default/
Not sure if the ID is the same for every installation, so it might be different on your end
