Invalid parameter
indir
My avatar does not change on the server
Have a look at this post
thx
This is normally my profile photo on TS5 but on some servers this does not happen. I want it to be on some servers too
On some servers it might not be possible as they are either wrongly configured, you don’t have permission to upload or they are using a modified TS server.
You could try with the TS3 Client and if that does not work you need to check with the server admins to solve the problem.
The profile pictures are stored for your identity so if you use the same identity it will be shown even if you join with the other client.
have ts3 client link?
