I would like to know if it is possible to configure my Windows TS3 client to be in half duplex mode. I want to use it to cross link to a DMR radio network. I have it working right now but it would be much better if it was in half duplex.
Ted, KC3OL
You may be able to get close to your goal using the the Echo reduction (Ducking) setting in the Capture settings area of Options. Can set the reduction to as high as 100dB.
Thanks for your suggestion. That helps to a certain degree.
Outside of that I think you would need to look into plugins, see if there is an existing one that does like you need, or if you can find a plugin author to write one. Or, get the plugin SDK and develop it yourself.
