I’m running a selfhosted server currently and I would like to increase the bandwidth rate limits.
For 4K 60FPS 10mbit is a bit low for fast paced games with a lot of foliage.
Same idea for voice where I’d like to increase the bitrate by a lot as I think 10KB/s is pretty low.
I wonder if this is why streams don’t look good in my testing, at least if they are 1080p 60fps or higher. I did find if you set a stream to 1080 60fps or source, then switch it to 720p, and switch it back, it helps.
Currently you can not increase the Bitrate further than 10 000 Kbps for streaming and 7.71 KiB/s for Opus Voice.
We do not recommend using Opus Music for voice channels, as the name suggests, its made for music playback.
