Is there a way to keep a channel on the bottom?
The server I’m on is setup so anyone can make a temporary channel for the game they’re playing, people love the new blue create channel button. The issue is whenever someone makes a channel it gets put below the AFK channel. Is there a way to sticky or anchor the afk channel so that it is always the bottom channel on the server?
You could set it up so that users can only create subchannels in a channel that is above the AFK channel.
I tried that, they couldn’t use the blue Create Chanel button to make sub channels and rioted so it was changed back.
You have to right click on the channel where the sub channel should be created
Or if you want to do it with the blue channel create button then your users have to drag the menu to the channel where the sub channel should go
TeamSpeak_3Xt098xmPz
