I have two Server Groups; First Lieutenant (1LT) and 5k Battles.
I want the 1LT to be able to add the 5k Battles when they need to. However, the option is not visible in the standard “pop up” menu and greyed out in the “Server Groups dialogue” scroll menu. When selected from the SG Dialogue, the error message comes up: (failed on i_client_needed_permission_modify_power)
I am Server Admin and am able to apply it. I have searched through these permissions with a fine toothed comb and cannot solve this problem. Thank you for any advice or insight.
(I apologize in advice, the forum would not let me upload text files here).
Permission’s Overview as a 1LT:
Server Groups
First Lieutenant
Use Privilege Keys to gain permissions 1 0 0
Join Permanent Channels 1 0 0
Join Semi-Permanent Channels 1 0 0
Join Temporary Channels 1 0 0
Channel Join Power 55 0 0
Channel Subscribe Power 55 0 0
Channel Description View Power 55 0 0
Icon ID 896245733 0 0
Group is Permanent 1 0 0
Group Auto Update Type 15 0 0
Group Sort ID 6020 0 0
Needed Group Modify Power 70 0 0
Group Member Add Power 55 0 0
Needed Group Member Add Power 70 0 0
Group Member Remove Power 55 0 0
Needed Group Member Remove Power 60 0 0
Max number of additional connections per Identity 0 0 0
Max Avatar Filesize (Bytes) 200000 0 0
Needed ServerQuery Client View Power 75 0 0
Needed Client Kick From Server Power 25 0 0
Needed Client Kick from Channel Power 25 0 0
Needed Client Ban Power 25 0 0
Client Move Power 35 0 0
Needed Client Move Power 35 0 0
Client Talk Power 42 0 0
File Download Power 25 0 0
File Browse Power 25 0 0
Download Quota per Client (MByte) -1 0 0
35K Battle Veteran
Channel Max Depth 5 0 0
Icon ID -711854391 0 0
Group Sort ID 8016 0 0
Needed Group Member Add Power 55 0 0
Needed Group Member Remove Power 55 0 0
Needed Client Move Power 25 0 0
Private Textmessage Power 25 0 0
Send Text Messages to Channel 1 0 0
Send Text Messages to Offline Clients 1 0 0
USA
Channel Delete Power 60 0 0
Icon ID -1862789332 0 0
Group Sort ID 9002 0 0
Needed Group Modify Power 75 0 0
Needed Group Member Add Power 60 0 0
Elite Tanker 5
Icon ID 1939100280 0 0
Group Sort ID 10012 0 0
Red Storm
Channel Modify Power 50 0 0
Channel Join Power 50 0 0
Channel Subscribe Power 50 0 0
Channel Description View Power 50 0 0
Icon ID 1275288198 0 0
Manage Icons 1 0 0
Group Auto Update Type 30 0 0
Group Sort ID 10051 0 0
Max Channel Subscriptions -1 0 0
Client Move Power 20 0 0
Client Talk Power 10 0 0
All
Manage Icons 1 0 0
Client
Channel
Another Lounge
Needed Channel Permission Modify Power 75
Needed Channel Delete Power 75
Needed Channel Join Power 40
Channel Groups
Guest
ServerQuery: View List of existing Channels 1
Group Auto Update Type 10
Channel Client
All
ServerQuery: View List of existing Channels 1 0 0
Needed Channel Permission Modify Power 75 0 0
Needed Channel Delete Power 75 0 0
Needed Channel Join Power 40 0 0
Manage Icons 1 0 0
Group Auto Update Type 10 0 0
And as a prospective 5k recipient:
Server Groups
Private
Icon ID 1809070100 0 0
Group Sort ID 6044 0 0
Client Talk Power 18 0 0
USA
Elite Tanker 5
Red Storm
Manage Icons 1 0 0
All
Manage Icons 1 0 0
Client
Channel
Another Lounge
Channel Groups
Guest
Channel Client
All
Manage Icons 1 0 0
Server Groups
Admin
ServerQuery: Login via ServerQuery 1 0 0
ServerQuery: Select Virtual Server 1 0 0
ServerQuery: View Virtual Server Info 1 0 0 75
View Virtual Server Connection Info 1 0 0 75
ServerQuery: View List of existing Channels 1 0 0 75
ServerQuery: Search for Channels 1 0 0 75
ServerQuery: View List of Clients online 1 0 0 75
ServerQuery: Search for Clients online 1 0 0 75
View List of known Client Identities from Database 1 0 0 75
Search for known Client Identities in Database 1 0 0 75
ServerQuery: View Client Database Information 1 0 0 75
ServerQuery: Search for Permission Assignments 1 0 0 75
ServerQuery: Search for Custom Client Properties 1 0 0 75
ServerQuery: Start this Virtual Server 100
ServerQuery: Stop this Virtual Server 100
View List of available Privilege Keys 1 0 0 75
Create new Privilege Key 1 0 0 75
Use Privilege Keys to gain permissions 1 0 0 75
Delete Privilege Key 1 0 0 75
b_virtualserver_apikey_add 1 0 0 75
b_virtualserver_apikey_manage 1 0 0 75
ServerQuery: View Virtual Server Logs 1 0 0 75
ServerQuery: Write to Virtual Server Log 1 0 0 100
Ignore Virtual Server Password 1 0 0 75
ServerQuery: Register for Event Notifications 1 0 0 75
ServerQuery: Unregister from Event Notifications 1 0 0 75
ServerQuery: Back Up Server Settings 1 0 0 75
Modify Virtual Server Name 1 0 0 75
Modify Virtual Server Welcome Message 1 0 0 75
Modify Virtual Server Max Clients 100
Modify Virtual Server Reserved Slots 1 0 0 75
Modify Virtual Server Password 1 0 0 75
Modify Virtual Server Default Server Group 1 0 0 75
Modify Virtual Server Default Channel Group 1 0 0 75
Modify Virtual Server Channel Admin Group 1 0 0 75
Modify Virtual Server Force Silence Limit 1 0 0 75
Modify Virtual Server Complaint Settings 1 0 0 75
Modify Virtual Server Anti-Flood Settings 100
Modify Virtual Server File-Transfer Settings 100
Modify Virtual Server File-Transfer Quotas 100
Modify Virtual Server Host Message 1 0 0 75
Modify Virtual Server Host Banner 1 0 0 75
Modify Virtual Server Host Button 1 0 0 75
Modify Virtual Server Port 100
Modify Virtual Server Autostart Behaviour 100
Modify Virtual Server Security Level 100
Modify Virtual Server Priority Speaker Dimm Modificator 1 0 0 75
Modify Virtual Server Log Settings 100
Modify Virtual Server Min Client Version 100
Modify Virtual Server Icon ID 1 0 0 75
Modify Virtual Server Announcement on Weblist 1 0 0 75
Modify Virtual Server Voice Encryption 1 0 0 75
Manage temporary server passwords 1 0 0 75
Manage own temporary server passwords 1 0 0 75
Edit default of temporary channel delete delay 1 0 0 75
Channel Min Depth 75
Channel Max Depth 10 0 0 75
Stop Channel Group Inheritance 75
Channel Permission Modify Power 75 0 0 75
ServerQuery: View Channel Info 1 0 0 75
Create Sub-Channels 1 0 0 75
Create Permanent Channels 1 0 0 75
Create Semi-Permanent Channels 1 0 0 75
Create Temporary Channels 1 0 0 75
Create Channels with Topic 1 0 0 75
Create Channels with Description 1 0 0 75
Create Channels with Password 1 0 0 75
b_channel_create_with_banner 1 0 0 75
Create Channels with Opus Voice Codec 1 0 0 75
Create Channels with Opus Music Codec 1 0 0 75
Create Channels with Max Codec Quality 10 0 0 75
Create Channel with Minimum Latency Factor 1 0 0 75
Create Channels with Max Clients 1 0 0 75
Create Channels with Max Family Clients 1 0 0 75
Create Channels with Sort Order 1 0 0 75
Create Default Channel 1 0 0 75
Create Channels with Needed Talk Power 1 0 0 75
Create Channels with Password only 75
Temporary channel delete delay 86400 0 0 75
Move Channels 1 0 0 75
Change Channel Type to Default 1 0 0 75
Change Channel Type to Permanent 1 0 0 75
Change Channel Type to Semi-Permanent 1 0 0 75
Change Channel Type to Temporary 1 0 0 75
Modify Channel Name 1 0 0 75
Modify Channel Topic 1 0 0 75
Modify Channel Description 1 0 0 75
Modify Channel Password 1 0 0 75
b_channel_modify_banner 1 0 0
Modify Channel Codec 1 0 0 75
Modify Channel Codec Quality 1 0 0 75
Modify Channel Latency Factor 1 0 0 75
Modify Channel Max Clients 1 0 0 75
Modify Channel Max Family Clients 1 0 0 75
Modify Channel Sort Order 1 0 0 75
Modify Channel Needed Talk Power 1 0 0 75
Channel Modify Power 75 0 0 75
Needed Channel Modify Power 75
Modify Channel Voice Encryption 1 0 0 75
Delete Permanent Channels 1 0 0 75
Delete Semi-Permanent Channels 1 0 0 75
Delete Temporary Channels 1 0 0 75
Force Deletion of Channels 1 0 0 75
Channel Delete Power 75 0 0 75
Join Permanent Channels 1 0 0 75
Join Semi-Permanent Channels 1 0 0 75
Join Temporary Channels 1 0 0 75
Ignore Channel Passwords 1 0 0 75
Ignore Channel Max Clients 1 0 0 75
Channel Join Power 75 0 0 75
Needed Channel Join Power 75
Channel Subscribe Power 75 0 0 75
Needed Channel Subscribe Power 75
Channel Description View Power 75 0 0 75
Needed Channel Description View Power 75
Icon ID 781421861 0 0 75
Icon Max Filesize (Bytes) 8192 0 0 75
Manage Icons 1 0 0 75
Group is Permanent 1 0 0 75
Group Auto Update Type 45 0 0 75
Group Auto Update Max Value 45 0 0
Group Sort ID 1 0 0 75
Show Group Name in Tree 75
ServerQuery: View List of Server Groups 1 0 0 75
View List of Server Group Permissions 1 0 0 75
View List of Server Group Members 1 0 0 75
ServerQuery: View List of Channel Groups 1 0 0 75
View List of Channel Group Permissions 1 0 0 75
View List of Channel Group Members 1 0 0 75
View List of Client Permissions 1 0 0 75
View List of Channel Permissions 1 0 0 75
View List of Channel Client Permissions 1 0 0 75
Create new Server Groups 1 0 0 75
Create new Channel Groups 1 0 0 75
Group Modify Power 75 0 0 75
Needed Group Modify Power 75 0 0 75
Group Member Add Power 75 0 0 75
Needed Group Member Add Power 75 0 0 75
Group Member Remove Power 75 0 0 75
Needed Group Member Remove Power 75 0 0 75
Delete existing Server Group 1 0 0 75
Delete existing Channel Group 1 0 0 75
Client Permission Modify Power 75 0 0 75
Needed Client Permission Modify Power 75 0 0 75
Max number of additional connections per Identity 10 0 0 75
Max Idle time (Seconds) 75
Max Avatar Filesize (Bytes) 200000 0 0 75
Max Channel Subscriptions -1 0 0 75
Client is Priority Speaker 75
Skip Channel Group Permissions 1 0 0 75
Force Push To Talk 75
Ignore Bans 1 0 0 75
Ignore Anti-Flood Measurements 1 0 0 75
Use Reserved Slots 1 0 0 75
Use Channel Commander 1 0 0 75
Request talk power in moderated channels 1 0 0 75
Delete other clients avatar 1 0 0 75
Sticky client 75
Ignore sticky client permission 1 0 0 75
ServerQuery: View Client Info 1 0 0 75
View Client Permission Overview 1 0 0 75
View Own Client Permission Overview 1 0 0 75
View Client Remote Address 1 0 0 75
ServerQuery Client View Power 75 0 0 75
Needed ServerQuery Client View Power 75 0 0 75
ServerQuery: View Custom Client Properties 1 0 0 75
Client Kick From Server Power 75 0 0 75
Needed Client Kick From Server Power 75 0 0 75
Client Kick from Channel Power 75 0 0 75
Needed Client Kick from Channel Power 75 0 0 75
Client Ban From Server Power 75 0 0 75
Needed Client Ban Power 75 0 0 75
Client Move Power 75 0 0 75
Needed Client Move Power 75 0 0 75
Client Complain Power 75 0 0 75
Needed Client Complain Power 75 0 0 75
View List of Client Complaints 1 0 0 75
Delete own Complaints 1 0 0 75
Delete all Complaints 1 0 0 75
View List of Ban Rules 1 0 0 75
Create new Ban Rules 1 0 0 75
Delete own Ban Rules 1 0 0 75
Delete all Ban Rules 1 0 0 75
Max Time for Ban Rules in seconds -1 0 0 75
Private Textmessage Power 75 0 0 75
Needed Private Textmessage Power 25 0 0 75
Send Text Messages to Server 1 0 0 75
Send Text Messages to Channel 1 0 0 75
Send Text Messages to Offline Clients 1 0 0 75
Needed Client Talk Power 75
Client Poke Power 75 0 0 75
Needed Client Poke Power 75
Grant Talk Power 1 0 0 75
Client Whisper Power 75
Needed Client Whisper Power 75
Modify all Client Descriptions 1 0 0 75
Modify own Client Description 1 0 0 75
ServerQuery: Modify Client Settings 1 0 0 75
Delete Client Database Properties 1 0 0 75
Create a ServerQuery Account 1 0 0 75
Browse files without channel password 1 0 0 75
ServerQuery: View List of active File-Transfers 1 0 0 75
File Upload Power 75 0 0 75
Needed File Upload Power 75
File Download Power 75 0 0 75
Needed File Download Power 75
File Delete Power 75 0 0 75
Needed File Delete Power 75
File Rename Power 75 0 0 75
Needed File Rename Power 75
File Browse Power 75 0 0 75
Needed File Browse Power 75
Directory Create Power 75 0 0 75
Needed Directory Create Power 75
Download Quota per Client (MByte) -1 0 0 75
Upload Quota per Client (MByte) 1310720 0 0 75
Server Admin
Icon ID -636920598 0 0 75
Group Sort ID 2 0 0 75
Group Modify Power 70 0 0 75
Group Member Add Power 70 0 0 75
Group Member Remove Power 70 0 0 75
Needed Group Member Remove Power 70 0 0 75
Permission Modify Power 70 0 0 75
Sticky client 75
ServerQuery Client View Power 70 0 0 75
Needed ServerQuery Client View Power 70 0 0 75
Client Kick From Server Power 70 0 0 75
Needed Client Kick From Server Power 70 0 0 75
Client Kick from Channel Power 70 0 0 75
Needed Client Kick from Channel Power 70 0 0 75
Client Ban From Server Power 70 0 0 75
Needed Client Ban Power 70 0 0 75
Client Move Power 70 0 0 75
Needed Client Move Power 70 0 0 75
Client Complain Power 70 0 0 75
Needed Client Complain Power 70 0 0 75
Private Textmessage Power 70 0 0 75
Needed Private Textmessage Power 50 0 0 75
Client Talk Power 10 0 0 75
Senior Recruitment Officer
Create Channels with Max Codec Quality 7 0 0
Channel Join Power 60 0 0
Channel Subscribe Power 60 0 0
Channel Description View Power 60 0 0
Icon ID 347062442 0 0
Group Sort ID 5017 0 0
Show Group Name in Tree 2 0 0
Colonel
Icon ID -932776732 0 0
Group Sort ID 6012 0 0
Max number of additional connections per Identity 2 0 0
Client Kick From Server Power 50 0 0
Needed Client Kick From Server Power 50 0 0
Client Kick from Channel Power 50 0 0
Needed Client Kick from Channel Power 50 0 0
Needed Client Ban Power 50 0 0
Client Move Power 45 0 0
Needed Client Move Power 45 0 0
Needed Client Complain Power 50 0 0
Client Talk Power 50 0 0
Client Poke Power 50 0 0
File Upload Power 50 0 0
File Download Power 50 0 0
File Delete Power 50 0 0
File Rename Power 50 0 0
File Browse Power 50 0 0
Directory Create Power 50 0 0
Upload Quota per Client (MByte) -1 0 0
15K Battle Veteran
Icon ID 1848208369 0 0
Group Sort ID 8008 0 0
USA
Elite Tanker 4
Icon ID 1891756328 0 0
Group Sort ID 10014 0 0
Red Storm
Manage Icons 1 0 0
All
Sticky client 75
Client
Channel
Lounge
Channel Groups
Guest
Channel Client
All
Sticky client 75
Alternate Tech Support role which can also apply 5k Battles:
Tech Support
Icon ID -1963116602 0 0
Group Sort ID 4014 0 0
