Ok I pulled manually the newest version by force.
Server is up and running again. But guys thats clearly bad practice on Teamspeak side.
Cmon you can do better than that after so many years of experience.
I managed to fix it by changing the line “image: teamspeaksystems/teamspeak6-server:latest” to “image: teamspeaksystems/teamspeak6-server:6.0.0-beta9” in the yaml file.
It seems latest tag is broken ?
**Why does it still fail to boot even after rolling back to Beta 8?
Log:**2026-05-01 10:34:33.645000|INFO |ServerLibPriv | |TeamSpeak Server v6.0.0-beta8 (2026-01-22 10:21:30)
2026-05-01 10:34:33.645325|INFO |ServerLibPriv | |SystemInformation: Linux 5.14.0-427.42.1.el9_4.x86_64 #1 SMP PREEMPT_DYNAMIC Thu Oct 31 14:01:51 UTC 2024 x86_64 Binary: 64bit
2026-05-01 10:34:33.953950|WARNING |Accounting | |Unable to open /opt/teamspeak/licensekey.dat
2026-05-01 10:34:33.954049|CRITICAL|Accounting | |The default license has expired. Please use the latest server version.
We’ll investigate what happened to the latest tag, but please manually update to the latest server version.
The license included with beta8 expired today and an update is mandatory for the server to start again.
Who had the genius idea to put the expiration date for the default license on a Friday that also is a national holiday in Germany?
Apart from that the entire licensing and self hosting situation feels extremely hostile towards self-hosters.
Edit: Found the edit button! I’ll still keep my other comment up until this one is unhidden or I can understand how it’s off-topic.
I don’t see any option to edit my comment as suggested, so I’m replying instead to ask which part of my comment exactly warrants flagging it as “off-topic”?
Hiding valid criticism is exactly the type of behavior I’d consider hostile…
Unable to get past this error on Docker Desktop (GUI)
I thought I would try out the GUI to introduce my less technical friends to Docker in a more gentle way than the CLI. Setup is easy, but each new container I spin up has the same licensing error. If anyone knows a solution without losing the data, feel free to chime in before I roast my server.
Since TeamSpeak 6 provides Docker support, I deployed a Docker container on my Linux server. After a few weeks, however, the license appears to have expired.
INFO |ServerLibPriv | |SystemInformation: Linux 6.8.0-111-generic #111-Ubuntu SMP PREEMPT_DYNAMIC Sat Apr 11 23:16:02 UTC 2026 x86_64 Binary: 64bit
INFO |DatabaseQuery | |dbPlugin name: SQLite3 plugin, Version 3, (c)TeamSpeak Systems GmbH
INFO |DatabaseQuery | |dbPlugin version: 3.51.3
INFO |DatabaseQuery | |checking database integrity (may take a while)
WARNING |Accounting | |Unable to open /var/tsserver/licensekey.dat
As a fix, I had to pull the latest TeamSpeak6 changes and restart my Docker container.
Why is it not possible to stay on a specific version? Why does the license expire?
To make sure you run an up to date version.
I guess since this server version is still in active development they want to reduce the number of outdated bug reports caused by outdated installations.
