Hello, I have a problem. I can’t log into my account in the app. Writes “Failed to login, please try again later.” What is causing this and how to solve it?
Have you already checked your internet connection and your email/password?
Please give more information on what are the steps you are following and maybe a screenshot of the error so people can help you
I’m not sure how I would answer you because I’m missing more details, if you’re logged in try to log out and then try to log in again and of course first of all check your internet connection. Enjoy me
Please show us a Client log, maybe they are errors
I have a problem, can someone help me? , I get this error: Critical backend Interaction Error
in the pag beta.teamspeak , in Ts too
I can’t log into the myteamspeak service too (both ts3 and ts5)
Same here, after getting a “failed to sync” tried to re-log.
Since then getting “Failed to login, please try again later.”
it works to me, so it’s not any manteinance, it’s a problem of your connection, check that and retry later
myteamspeak.com page is working here too, only getting it from within the client
yeah beta.teamspeak.com isn’t working too
After restarting TeamSpeak, I am logged out in both clients and also cannot connect to myTeamSpeak. On the beta.teamspeak.com site I can’t log in either, but on myteamspeak.com I can.
I am also facing issues logging into MyTeamspeak via the client. I have the following client log:
28/01/2021 21:19:58 Info tried to request user integration info without valid session
28/01/2021 21:20:13 ProtobufRPC Warning Server at URL https://clientapi.myteamspeak.com/authentication responded: 502 Bad Gateway
28/01/2021 21:20:13 ClientUI Warning Account login failed, server currently not available. Retry in few minutes.
28/01/2021 21:20:13 SCHandler Info try to delete mytsid while no valid mytsid is set - abort
The authentication API appears to be throwing HTTP code 502 - Bad Gateway.
Issue seems to be fixed, no more 502, login working
Yes, I confirm.
yeah, fixed to me, too
TeamSpeak has written something about this.
→ https://twitter.com/teamspeak/status/1354910025144283141
