Login via Teamspeak 5 & Website is not possible
Hey I can’t log in to my Teamspeak 5 account let alone the website, I entered the password correctly
Hey @BySizee,
The Login in the Client is working,
same goes for the myTeamSpeak Website.
Are you getting any error messages when you try to log in?
Maybe you can post your tschat.log and the ts5_client.log
which you can found under the following path: %localappdata%\TeamSpeak
Greetings
Everything is fine, thanks anyway :slight_smile:
