How can I download without problems?
@Gamer92000 fixed this Plugin
You can Download it here:
https://julianimhof.de/files/patchedPlugins/lua-11win64.ts3_plugin
The problem in your case is not the API version I fixed.
I don’t know with which MSVC version this was compiled.
I have to assume that you need to install an additional C++ redist.
This is installed on most systems due to a lot of games requiring them.
You can just try to install the latest one from the MS website ( 64bit or 32bit ).
Whether you need 32 or 64 bit depends on the TeamSpeak installation.
I have all the packages
I installed the one in the link you shared.
But the problem is not solved
I also reinstalled TeamSpeak but it didn’t give a solution
Hmmm, all I can say is that it works just fine for me.
The way I path those plugins is to simply go into the binary itself and replace the API level with a newer one.
So this error should not be related to that at least.
Can you give us any more information about your OS?
I removed all packages and TeamSpeak program with HiBit program, I reinstalled everything, but my problem is not solved, I would be very happy if anyone can help.
I formatted my computer, I did a clean install, I installed all the necessary components, but the problem was not solved.
an annoying situation
22.10.2021 11:01:48 Addon_Download_Manager Info Download completed: C:/Users/hide/AppData/Local/Temp/lua-11win64_5d003a77563f4.ts3_plugin Addon_Uuid:1ea680fd-dfd2-49ef-a259-74d27593b867 Version: 2
22.10.2021 11:01:49 Addon_Install_Manager Debug (Package Installer): Writing /plugins/lua_plugin/testmodule/events.lua
22.10.2021 11:01:49 Addon_Install_Manager Debug (Package Installer): Writing /plugins/lua_plugin/testmodule/init.lua
22.10.2021 11:01:49 Addon_Install_Manager Debug (Package Installer): Writing /plugins/lua_plugin/ts3autoload.lua
22.10.2021 11:01:49 Addon_Install_Manager Debug (Package Installer): Writing /plugins/lua_plugin/ts3defs.lua
22.10.2021 11:01:49 Addon_Install_Manager Debug (Package Installer): Writing /plugins/lua_plugin/ts3errors.lua
22.10.2021 11:01:49 Addon_Install_Manager Debug (Package Installer): Writing /plugins/lua_plugin/ts3events.lua
22.10.2021 11:01:49 Addon_Install_Manager Debug (Package Installer): Writing /plugins/lua_plugin/ts3init.lua
22.10.2021 11:01:49 Addon_Install_Manager Debug (Package Installer): Writing /plugins/lua_plugin_win64.dll
22.10.2021 11:01:49 Addon_Install_Manager Debug (Package Installer): Add-On successfully installed and activated.
22.10.2021 11:01:49 Addon_Install_Manager Info Addon installed: Lua
22.10.2021 11:01:49 Addons Info Installing addon Lua
22.10.2021 11:01:49 Plugins Info Loading plugin: lua_plugin_win64.dll
I guess there is nothing more in the logs?
I’ll try to get in contact with the developers about this.
22.10.2021 16:52:19 Info TeamSpeak Client 3.5.6 (2020-11-25 13:53:42)
22.10.2021 16:52:19 Info SystemInformation: Windows 10 (19043) x64 (AMD or Intel) Binary: 64bit
22.10.2021 16:52:19 Info Using hardware aes
22.10.2021 16:52:19 Direct Sound Debug setting timer resolution to 1ms -
22.10.2021 16:52:19 ClientUI Info OpenGL Info: LibGLES, Vendor: Google Inc., Renderer: ANGLE (Intel(R) HD Graphics 520 Direct3D11 vs_5_0 ps_5_0), Version: OpenGL ES 2.0 (ANGLE 2.1.0.57ea533f79a7)
22.10.2021 16:52:19 Info *** Time [ICONMANGER]: 118
22.10.2021 16:52:19 Addons Info Checking for addon updates...
22.10.2021 16:52:19 Plugins Info Loading plugin: teamspeak_control_plugin_win64.dll
22.10.2021 16:52:19 ControlPlugin Info Control Plugin started, accepting connections
22.10.2021 16:52:19 Plugins Info Loading plugin: lua_plugin_win64.dll
22.10.2021 16:52:19 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
22.10.2021 16:52:19 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
22.10.2021 16:52:19 Addon Info Addon up to date.
22.10.2021 16:52:19 Info *** Time [BUILD_GUI]: 414
22.10.2021 16:52:20 Info *** Time [SERVERVIEW]: 443
22.10.2021 16:52:20 Info *** Time [SERVERVIEWMANAGER]: 463
22.10.2021 16:52:20 Info *** Time [MAINWINDOW]: 895
22.10.2021 16:52:20 Info *** Time [INIT]: 896
22.10.2021 16:52:20 ClientUI Info Qt version: 5.12.3
22.10.2021 16:52:20 ClientUI Info Using configuration location: C:\Users\Ulaş Boynueğri\AppData\Roaming\TS3Client\settings.db
22.10.2021 16:52:20 ClientUI Info Last update check was: Cum Eki 22 13:09:35 2021
22.10.2021 16:52:20 Info Statistics report: Not yet, next report on Çar Kas 3 13:11:44 2021
22.10.2021 16:52:20 Bookmarks Info Collecting autoconnect bookmarks
22.10.2021 16:52:21 Newsticker Info Newsticker next check: Cmt Eki 23 10:20:51 2021 GMT
22.10.2021 16:52:22 ClientUI Info Connect to server: x
22.10.2021 16:52:22 ClientUI Info Trying to resolve x
22.10.2021 16:52:22 TSDNS Info Trying to resolve server name: seasro
22.10.2021 16:52:22 TSDNS Info Server name successfully resolved
22.10.2021 16:52:22 TSDNS Info Lookup: x, parse result: IPv4 x 9000
22.10.2021 16:52:22 TSDNS Info Server name resolved to IPs
22.10.2021 16:52:22 ClientUI Info Lookup finished: ip=x port=9000 query=seasro error=0
22.10.2021 16:52:22 ClientUI Info Resolve successful: x:9000
22.10.2021 16:52:22 ClientUI Info Initiating connection: x:9000
22.10.2021 16:52:22 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
22.10.2021 16:52:22 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
22.10.2021 16:52:22 Windows Audio Session Debug WAS::openDevice-enter - {0.0.0.00000000}.{8857642a-edd1-4fd7-b538-26b2421e00c4}
22.10.2021 16:52:22 Windows Audio Session Devel Mix Format: SRate:48000 Bitrate: 32 Channels: 2 - VoiceMeeter Aux Input (VB-Audio VoiceMeeter AUX VAIO)
22.10.2021 16:52:22 Windows Audio Session Devel Initializing with mix format. - VoiceMeeter Aux Input (VB-Audio VoiceMeeter AUX VAIO)
22.10.2021 16:52:22 Windows Audio Session Info Initialized with 2 channels in 32bit, 48kHz. - VoiceMeeter Aux Input (VB-Audio VoiceMeeter AUX VAIO)
22.10.2021 16:52:22 Windows Audio Session Devel WAS Buffer size: 1056 - VoiceMeeter Aux Input (VB-Audio VoiceMeeter AUX VAIO)
22.10.2021 16:52:22 Windows Audio Session Debug WAS::openDevice-leave - {0.0.0.00000000}.{8857642a-edd1-4fd7-b538-26b2421e00c4}
22.10.2021 16:52:22 Windows Audio Session Debug WAS::startDevice-enter - {0.0.0.00000000}.{8857642a-edd1-4fd7-b538-26b2421e00c4}
22.10.2021 16:52:22 Windows Audio Session Debug WAS::startDevice-leave - {0.0.0.00000000}.{8857642a-edd1-4fd7-b538-26b2421e00c4}
22.10.2021 16:52:22 Windows Audio Session Debug WAS::openDevice-enter - {0.0.1.00000000}.{543e960e-d21b-4bf6-8d55-a1d04499b7e8}
22.10.2021 16:52:22 Windows Audio Session Devel Mix Format: SRate:44100 Bitrate: 32 Channels: 2 - VoiceMeeter Output (VB-Audio VoiceMeeter VAIO)
22.10.2021 16:52:22 Windows Audio Session Devel Initializing with mix format. - VoiceMeeter Output (VB-Audio VoiceMeeter VAIO)
22.10.2021 16:52:22 Windows Audio Session Info Initialized with 2 channels in 32bit, 44.1kHz. - VoiceMeeter Output (VB-Audio VoiceMeeter VAIO)
22.10.2021 16:52:22 Windows Audio Session Devel WAS Buffer size: 970 - VoiceMeeter Output (VB-Audio VoiceMeeter VAIO)
22.10.2021 16:52:22 Windows Audio Session Debug WAS::openDevice-leave - {0.0.1.00000000}.{543e960e-d21b-4bf6-8d55-a1d04499b7e8}
22.10.2021 16:52:22 Windows Audio Session Debug WAS::startDevice-enter - {0.0.1.00000000}.{543e960e-d21b-4bf6-8d55-a1d04499b7e8}
22.10.2021 16:52:22 Windows Audio Session Debug WAS::startDevice-leave - {0.0.1.00000000}.{543e960e-d21b-4bf6-8d55-a1d04499b7e8}
22.10.2021 16:52:22 ClientUI Info Connect status: Connecting
22.10.2021 16:52:22 PktHandler Devel Puzzle solve time: 0
22.10.2021 16:52:23 ClientUI Info Connect status: Connected
22.10.2021 16:52:23 SCHandler Warning Received unknown packet
22.10.2021 16:52:23 ClientUI Info Connect status: Establishing connection
22.10.2021 16:52:23 ClientUI Info Connect status: Connection established
did you get any results?
