Hello, ive tried to add an add-on on team speak Mac client it says add-on successfully installed but then when I go into addons in options on team speak it doesn’t show up, ive tried restarting, trying to reinstall and still nothing. thank you in advance for any help.
my Guess:
There is no content for MacOs in that plugin installer, but the dev did just copy text into the install file and this one contained MacOS.
Whys guess?`I have no idea what Plugin we are talking about.
Hi, thanks fir your reply sorry I didn’t included the plugin it is the plugin task force radio for team speak thank you
Afaik this is a Windows Only plugin. In that case my guess was right. There are no files included for MacOS (at least in the versions i could find).
