Mask on channels icon
We use PNG icons and I noticed that some masks are on or under the channel icon which doesn’t look very nice
if you remove <can’t insert code> this looks better
or
Format does not matter in this case
I used SVG icons.
In TeamSpeak 3 SVG icons look very rough
TS3
TS5
Please do not write OFF TOPIC if you do not understand what this topic is about
my icons are specially made with transparent symbols inside to look beautiful on any background and in TeamSpeak 5 they don’t look pretty because of the mask
Here I have sent you SCREENSHOTS with SVG icons
I don’t need a transparent background
Now do you know what I mean? If you don’t understand what I’m saying, don’t continue topic!
So, basically you want that if you set custom icons, placeholder one gets either fully replaced or only white background stays, which kinda acts as a border.
For those who don’t understand, he wants gray parts of icons to disappear.
If I’m wrong, then I don’t know. If I’m right, this is GREAT idea.
The underlying mask is a problem for my sever as well. It makes the icons really hard to see.
