Tento me conectar em um server mas só dá maximum number of connections with the same identity exceeded
Make sure that you are not connected with the same identity on other devices or across multiple tabs on the server.
This message has the answer. You have exceeded the allowed clones number.
If you connect too many times to the same server with the same identity.
You can set a number greater in:
Permissions > Server Groups > … your server group… > Client > Modify > i_client_max_clones_uid
Another possibility is that you try to reconnect too fast, to the server.
