[MEGATHREAD] TeamSpeak Messenger Connection Issue | October 2024
Hello @Proanka and welcome to the TeamSpeak Forum,
The Issue is known, but seems to be fixed right now.
Check out the latest statement here:
hi there, a few hours ago everything was fine, but now we have the same problems as in the last few days. no or only unstable connection to the teamspeak server :cry: :sob:
Yeah. I still have the same problem also.
TeamSpeak app Disconnected connect to internet error.
i just downloaded Teamspeak and it says disconnected in bottom left, in group chats and in contacts and its trys connecting again once like 10 secs and goes back to disconnected. I have no issues with my internet and my TS3 app works pretty fine with my server. i cant use the new app and i cant create Group chats because of disconnected error. I dont know how the GC and Contact features work but i wanna use GC with my friend so i need little help.
There has been some issues in the past days, so it might be that the service is again offline or has stability problems.
https://community.teamspeak.com/t/megathread-teamspeak-messenger-connection-issue-october-2024/51651/42?u=leonmarcelh
not solved
thanks
Hey all, we are again experiencing heavy traffic, so you may experience issues connecting to the messenger.
We are actively monitoring the situation and working on a solution.
Thanks!
2 of the causes of traffic
is the blocking of the discord platform in Russia and Turkey 2 days apart
the opportunity for now is so good that you can get more of the player community in turkey as a turkish I have been using ts3 since 2015, I participated in teamspeak5 beta tests and I even have a badge.
If I were you, I would add a discord-like free server feature, persistent messaging and screen sharing feature, even if it is in beta version, to win the Turkish player community.
thanks for all the work you have done so far
In the meantime, if there is language support in teamspeak5, I would like to complete if there is a link that I can help with the Turkish language.
Back to stable, and as before, if you had any issues, please try again! Thank you all!
No, its not (12.10.2024)
I am experiencing the same issue too.
still the worst screen on Teamspeak for a few days
The issue still remains for me (teamspeak cannot connect to the messaging service most of the time), and even when it does connect, messages take a long time to send (up to a minute).
All other messengers I use on this PC work fine, so it’s most likely not on my end.
is there no way to fix these problems ? it is very bad :thinking: :confused: :disappointed: :cry: :sob:
I’m using first time team speak so don’t have much idea.
Still nothing for me. i just downloaded and signed up and I cant use it
