[MEGATHREAD] TeamSpeak Messenger Connection Issue
This is a megathread to collect all recently incoming reports of connection issues with the TeamSpeak 6 Client. Please refrain from creating new topics about this issue and use this thread instead.
We are aware of the ongoing issue and are working hard to fix it. Any updates regarding the connection issue will be posted in this thread, please pay attention to Staff Messages.
We apologize for the inconvenience and thank you for your patience.
Only use this Thread if you cannot connect to the messenger:
Update 6. February
We have identified an issue where accounts are attempting to connect to a chat server that is no longer available. To resolve this, we need to manually clear the chat data on the affected accounts, which is currently not possible on the production myTS system.
The issue has been identified, and a fix is on the way and will be implemented soon.
it says you are not connected to messenger services
TS Chat log:
[2025-01-20 19:29:42.077] [info] TSBindingBrowserTSChat ctor
[2025-01-20 19:29:42.077] [info] TSChat library version: 1
[2025-01-20 19:30:01.068] [info] update homebase: tsChatId=0
[2025-01-20 19:30:01.068] [info] Updating homebase to 0
[2025-01-20 19:30:01.068] [info] Homebase deleted, tsChatId = 0
[2025-01-20 19:30:01.068] [error] No homebase found
[2025-01-20 19:30:01.129] [info] TSBindingBrowserTSChat::create scHandlerId=0 server_identifier= specifier= endpoint=CENTRAL
[2025-01-20 19:30:01.131] [info] Save data path: server_identifier=chat-5.tmspk.net specifier=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 => C:\Users\Symo\AppData\Local\TeamSpeak\Cache\Default\tschat\Zjk4M2EyZmMwZjI3Y2M0ODhjYTE1YmRlZTEzZGY3MTM
[2025-01-20 19:30:01.131] [info] Matrix client create: matrixHost=chat-5.tmspk.net
[2025-01-20 19:30:01.131] [error] Failed to load save data (open C:\Users\Symo\AppData\Local\TeamSpeak\Cache\Default\tschat\Zjk4M2EyZmMwZjI3Y2M0ODhjYTE1YmRlZTEzZGY3MTM: The system cannot find the file specified.)
[2025-01-20 19:30:01.145] [info] Creating fresh store
[2025-01-20 19:30:01.146] [info] new crypto account on init - fresh
[2025-01-20 19:30:01.146] [info] created new group session storage
[2025-01-20 19:30:01.160] [info] connect: ts_chat_id=1 displayname=Symoaka presence=online
[2025-01-20 19:30:01.373] [error] Failed to move homebase to central: 1
[2025-01-20 19:30:02.212] [info] Login successful
[2025-01-20 19:30:02.568] [info] Initial sync… nextBatch=
[2025-01-20 19:30:52.744] [info] Initial sync failed: invalid status code: 504
[2025-01-20 19:30:52.744] [warning] TSChat_Connect failed: invalid status code: 504
[2025-01-20 19:30:52.744] [error] Connection failed: err=1
[2025-01-20 19:30:52.746] [info] stop: ts_chat_id=1
[2025-01-20 19:30:52.763] [info] Save data path: server_identifier=chat-5.tmspk.net specifier=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 => C:\Users\Symo\AppData\Local\TeamSpeak\Cache\Default\tschat\Zjk4M2EyZmMwZjI3Y2M0ODhjYTE1YmRlZTEzZGY3MTM
[2025-01-20 19:30:52.769] [info] destroy: ts_chat_id=1
[2025-01-20 19:31:02.754] [info] TSBindingBrowserTSChat::create scHandlerId=0 server_identifier= specifier= endpoint=CENTRAL
[2025-01-20 19:31:02.755] [info] Save data path: server_identifier=chat-5.tmspk.net specifier=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 => C:\Users\Symo\AppData\Local\TeamSpeak\Cache\Default\tschat\Zjk4M2EyZmMwZjI3Y2M0ODhjYTE1YmRlZTEzZGY3MTM
[2025-01-20 19:31:02.755] [info] Matrix client create: matrixHost=chat-5.tmspk.net
[2025-01-20 19:31:02.760] [info] Created store from save data, loaded transactionId=1, searchDbSerial=0
[2025-01-20 19:31:02.760] [info] Init crypto storage
[2025-01-20 19:31:02.760] [info] created new group session storage
[2025-01-20 19:31:02.760] [warning] get key request data: unexpected end of JSON input
[2025-01-20 19:31:02.793] [info] connect: ts_chat_id=2 displayname=Symoaka presence=online
[2025-01-20 19:31:03.039] [info] Initial sync… nextBatch=
[2025-01-20 19:31:03.131] [info] Initial sync failed: invalid status code: 503
[2025-01-20 19:31:03.131] [warning] TSChat_Connect failed: invalid status code: 503
[2025-01-20 19:31:03.131] [error] Connection failed: err=1
[2025-01-20 19:31:03.141] [info] stop: ts_chat_id=2
[2025-01-20 19:31:03.156] [info] Save data path: server_identifier=chat-5.tmspk.net specifier=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 => C:\Users\Symo\AppData\Local\TeamSpeak\Cache\Default\tschat\Zjk4M2EyZmMwZjI3Y2M0ODhjYTE1YmRlZTEzZGY3MTM
[2025-01-20 19:31:03.163] [info] destroy: ts_chat_id=2
[2025-01-20 19:31:23.149] [info] TSBindingBrowserTSChat::create scHandlerId=0 server_identifier= specifier= endpoint=CENTRAL
[2025-01-20 19:31:23.149] [info] Save data path: server_identifier=chat-5.tmspk.net specifier=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 => C:\Users\Symo\AppData\Local\TeamSpeak\Cache\Default\tschat\Zjk4M2EyZmMwZjI3Y2M0ODhjYTE1YmRlZTEzZGY3MTM
[2025-01-20 19:31:23.150] [info] Matrix client create: matrixHost=chat-5.tmspk.net
[2025-01-20 19:31:23.155] [info] Created store from save data, loaded transactionId=1, searchDbSerial=2
[2025-01-20 19:31:23.155] [info] Init crypto storage
[2025-01-20 19:31:23.155] [info] created new group session storage
[2025-01-20 19:31:23.155] [warning] get key request data: unexpected end of JSON input
[2025-01-20 19:31:23.172] [info] connect: ts_chat_id=3 displayname=Symoaka presence=online
[2025-01-20 19:31:23.448] [info] Initial sync… nextBatch=
[2025-01-20 19:31:48.112] [info] Initial sync failed: invalid status code: 502
[2025-01-20 19:31:48.112] [warning] TSChat_Connect failed: invalid status code: 502
[2025-01-20 19:31:48.112] [error] Connection failed: err=1
[2025-01-20 19:31:48.121] [info] stop: ts_chat_id=3
[2025-01-20 19:31:48.137] [info] Save data path: server_identifier=chat-5.tmspk.net specifier=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 => C:\Users\Symo\AppData\Local\TeamSpeak\Cache\Default\tschat\Zjk4M2EyZmMwZjI3Y2M0ODhjYTE1YmRlZTEzZGY3MTM
[2025-01-20 19:31:48.143] [info] destroy: ts_chat_id=3
[2025-01-20 19:32:28.139] [info] TSBindingBrowserTSChat::create scHandlerId=0 server_identifier= specifier= endpoint=CENTRAL
[2025-01-20 19:32:28.140] [info] Save data path: server_identifier=chat-5.tmspk.net specifier=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 => C:\Users\Symo\AppData\Local\TeamSpeak\Cache\Default\tschat\Zjk4M2EyZmMwZjI3Y2M0ODhjYTE1YmRlZTEzZGY3MTM
[2025-01-20 19:32:28.140] [info] Matrix client create: matrixHost=chat-5.tmspk.net
[2025-01-20 19:32:28.145] [info] Created store from save data, loaded transactionId=1, searchDbSerial=2
[2025-01-20 19:32:28.145] [info] Init crypto storage
[2025-01-20 19:32:28.145] [info] created new group session storage
[2025-01-20 19:32:28.145] [warning] get key request data: unexpected end of JSON input
[2025-01-20 19:32:28.155] [info] connect: ts_chat_id=4 displayname=Symoaka presence=online
[2025-01-20 19:32:28.409] [info] Initial sync… nextBatch=
[2025-01-20 19:33:18.717] [info] Initial sync failed: invalid status code: 502
[2025-01-20 19:33:18.718] [warning] TSChat_Connect failed: invalid status code: 502
[2025-01-20 19:33:18.718] [error] Connection failed: err=1
[2025-01-20 19:33:18.748] [info] stop: ts_chat_id=4
[2025-01-20 19:33:18.759] [info] Save data path: server_identifier=chat-5.tmspk.net specifier=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 => C:\Users\Symo\AppData\Local\TeamSpeak\Cache\Default\tschat\Zjk4M2EyZmMwZjI3Y2M0ODhjYTE1YmRlZTEzZGY3MTM
[2025-01-20 19:33:18.765] [info] destroy: ts_chat_id=4
[2025-01-20 19:34:16.838] [info] TSBindingBrowserTSChat dtor
[2025-01-20 19:34:42.618] [info] TSBindingBrowserTSChat ctor
[2025-01-20 19:34:42.618] [info] TSChat library version: 1
[2025-01-20 19:34:43.504] [info] TSBindingBrowserTSChat::create scHandlerId=0 server_identifier= specifier= endpoint=CENTRAL
[2025-01-20 19:34:43.505] [info] Save data path: server_identifier=chat-5.tmspk.net specifier=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 => C:\Users\Symo\AppData\Local\TeamSpeak\Cache\Default\tschat\Zjk4M2EyZmMwZjI3Y2M0ODhjYTE1YmRlZTEzZGY3MTM
[2025-01-20 19:34:43.505] [info] Matrix client create: matrixHost=chat-5.tmspk.net
[2025-01-20 19:34:43.513] [info] Created store from save data, loaded transactionId=1, searchDbSerial=2
[2025-01-20 19:34:43.513] [info] Init crypto storage
[2025-01-20 19:34:43.514] [info] created new group session storage
[2025-01-20 19:34:43.514] [warning] get key request data: unexpected end of JSON input
[2025-01-20 19:34:43.539] [info] connect: ts_chat_id=1 displayname=Symoaka presence=online
[2025-01-20 19:34:43.809] [info] Initial sync… nextBatch=
[2025-01-20 19:35:06.933] [info] Initial sync failed: invalid status code: 502
[2025-01-20 19:35:06.933] [warning] TSChat_Connect failed: invalid status code: 502
[2025-01-20 19:35:06.933] [error] Connection failed: err=1
[2025-01-20 19:35:06.942] [info] stop: ts_chat_id=1
[2025-01-20 19:35:06.965] [info] Save data path: server_identifier=chat-5.tmspk.net specifier=CiAvy1ibw3zwHk67lTmPwv5GJ9r1rONxd2JfZPvZB7xW5RKUAQpwzQMjrQkZ+mHz4zw2QtE1X9VKtqy4o7jF6S4SZpSS8ZBHB7QCcrOpQMoxIfpoAstHhJY7t8KKoICn5AstUzei7RMzn4B9bH4n1/PTIAFhNZamY7xLFVbjab7SHVl2i3MhneTNTgPkwZHXizlVH4ErdxIg2N6XzaolT9uKW8QGytptLkhW+aJS+5zPn5H3qJi6hVcYgICAgPCswq7yASIhAcNm67OO7p2R9TmO6wb08eW+h0vjbQe30nfnYXfvwqVDKrABuPQsmsx8RV59xg1ZyyaArZuIcp+xglPlYlneAFVey58tYF1sYaaDpO95Us3kMEFShcN6QeyO23TheEtqmuyHCwEA3lhpecKgocpIjyps49qcdJg3910Y2t8LsX7loEBdJsEAEs6mABjBWoAAAABCVGVhbVNwZWFrIFN5c3RlbXMgR21iSAAAI8Rq9g2zykckeBwWKLwIGGICCcXQTnP32eDHpZ00M5IGFqwJ9hbTM+4= => C:\Users\Symo\AppData\Local\TeamSpeak\Cache\Default\tschat\Zjk4M2EyZmMwZjI3Y2M0ODhjYTE1YmRlZTEzZGY3MTM
[2025-01-20 19:35:06.973] [info] destroy: ts_chat_id=1
[2025-01-20 19:35:16.955] [info] TSBindingBrowserTSChat::create scHandlerId=0 server_identifier= specifier= endpoint=CENTRAL
[2025-01-20 19:35:16.956] [info] Save data path: server_identifier=chat-5.tmspk.net specifier=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 => C:\Users\Symo\AppData\Local\TeamSpeak\Cache\Default\tschat\Zjk4M2EyZmMwZjI3Y2M0ODhjYTE1YmRlZTEzZGY3MTM
[2025-01-20 19:35:16.957] [info] Matrix client create: matrixHost=chat-5.tmspk.net
[2025-01-20 19:35:16.962] [info] Created store from save data, loaded transactionId=1, searchDbSerial=2
[2025-01-20 19:35:16.962] [info] Init crypto storage
[2025-01-20 19:35:16.962] [info] created new group session storage
[2025-01-20 19:35:16.962] [warning] get key request data: unexpected end of JSON input
[2025-01-20 19:35:16.990] [info] connect: ts_chat_id=2 displayname=Symoaka presence=online
[2025-01-20 19:35:17.234] [info] Initial sync… nextBatch=
[2025-01-20 19:35:41.488] [info] TSBindingBrowserTSChat dtor
[2025-01-20 19:35:41.488] [warning] Failed to stop tschat connection on shutdown, err=1
[2025-01-20 19:35:41.489] [info] Save data path: server_identifier=chat-5.tmspk.net specifier=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 => C:\Users\Symo\AppData\Local\TeamSpeak\Cache\Default\tschat\Zjk4M2EyZmMwZjI3Y2M0ODhjYTE1YmRlZTEzZGY3MTM
[2025-01-20 19:36:34.331] [info] TSBindingBrowserTSChat ctor
[2025-01-20 19:36:34.331] [info] TSChat library version: 1
[2025-01-20 19:36:35.168] [info] TSBindingBrowserTSChat::create scHandlerId=0 server_identifier= specifier= endpoint=CENTRAL
[2025-01-20 19:36:35.169] [info] Save data path: server_identifier=chat-5.tmspk.net specifier=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 => C:\Users\Symo\AppData\Local\TeamSpeak\Cache\Default\tschat\Zjk4M2EyZmMwZjI3Y2M0ODhjYTE1YmRlZTEzZGY3MTM
[2025-01-20 19:36:35.169] [info] Matrix client create: matrixHost=chat-5.tmspk.net
[2025-01-20 19:36:35.175] [info] Created store from save data, loaded transactionId=1, searchDbSerial=2
[2025-01-20 19:36:35.175] [info] Init crypto storage
[2025-01-20 19:36:35.175] [info] created new group session storage
[2025-01-20 19:36:35.175] [warning] get key request data: unexpected end of JSON input
[2025-01-20 19:36:35.187] [info] connect: ts_chat_id=1 displayname=Symoaka presence=online
[2025-01-20 19:36:35.407] [info] Initial sync… nextBatch=
[2025-01-20 19:36:54.668] [info] Initial sync failed: invalid status code: 503
[2025-01-20 19:36:54.668] [warning] TSChat_Connect failed: invalid status code: 503
[2025-01-20 19:36:54.668] [error] Connection failed: err=1
[2025-01-20 19:36:54.678] [info] stop: ts_chat_id=1
[2025-01-20 19:36:54.709] [info] Save data path: server_identifier=chat-5.tmspk.net specifier=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 => C:\Users\Symo\AppData\Local\TeamSpeak\Cache\Default\tschat\Zjk4M2EyZmMwZjI3Y2M0ODhjYTE1YmRlZTEzZGY3MTM
[2025-01-20 19:36:54.715] [info] destroy: ts_chat_id=1
[2025-01-20 19:37:04.690] [info] TSBindingBrowserTSChat::create scHandlerId=0 server_identifier= specifier= endpoint=CENTRAL
[2025-01-20 19:37:04.691] [info] Save data path: server_identifier=chat-5.tmspk.net specifier=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 => C:\Users\Symo\AppData\Local\TeamSpeak\Cache\Default\tschat\Zjk4M2EyZmMwZjI3Y2M0ODhjYTE1YmRlZTEzZGY3MTM
[2025-01-20 19:37:04.691] [info] Matrix client create: matrixHost=chat-5.tmspk.net
[2025-01-20 19:37:04.696] [info] Created store from save data, loaded transactionId=1, searchDbSerial=2
[2025-01-20 19:37:04.696] [info] Init crypto storage
[2025-01-20 19:37:04.696] [info] created new group session storage
[2025-01-20 19:37:04.696] [warning] get key request data: unexpected end of JSON input
[2025-01-20 19:37:04.705] [info] connect: ts_chat_id=2 displayname=Symoaka presence=online
[2025-01-20 19:37:04.964] [info] Initial sync… nextBatch=
[2025-01-20 19:39:01.249] [info] TSBindingBrowserTSChat ctor
[2025-01-20 19:39:01.249] [info] TSChat library version: 1
[2025-01-20 19:39:02.370] [info] TSBindingBrowserTSChat::create scHandlerId=0 server_identifier= specifier= endpoint=CENTRAL
[2025-01-20 19:39:02.372] [info] Save data path: server_identifier=chat-5.tmspk.net specifier=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 => C:\Users\Symo\AppData\Local\TeamSpeak\Cache\Default\tschat\Zjk4M2EyZmMwZjI3Y2M0ODhjYTE1YmRlZTEzZGY3MTM
[2025-01-20 19:39:02.372] [info] Matrix client create: matrixHost=chat-5.tmspk.net
[2025-01-20 19:39:02.373] [error] Failed to load save data (open C:\Users\Symo\AppData\Local\TeamSpeak\Cache\Default\tschat\Zjk4M2EyZmMwZjI3Y2M0ODhjYTE1YmRlZTEzZGY3MTM: The system cannot find the file specified.)
[2025-01-20 19:39:02.379] [info] Creating fresh store
[2025-01-20 19:39:02.379] [info] new crypto account on init - fresh
[2025-01-20 19:39:02.379] [info] created new group session storage
[2025-01-20 19:39:02.387] [info] connect: ts_chat_id=1 displayname=Symoaka presence=online
[2025-01-20 19:39:03.418] [info] Login successful
[2025-01-20 19:39:03.700] [info] Initial sync… nextBatch=
[2025-01-20 19:39:43.958] [info] Initial sync failed: invalid status code: 502
[2025-01-20 19:39:43.958] [warning] TSChat_Connect failed: invalid status code: 502
[2025-01-20 19:39:43.958] [error] Connection failed: err=1
[2025-01-20 19:39:43.969] [info] stop: ts_chat_id=1
[2025-01-20 19:39:43.987] [info] Save data path: server_identifier=chat-5.tmspk.net specifier=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 => C:\Users\Symo\AppData\Local\TeamSpeak\Cache\Default\tschat\Zjk4M2EyZmMwZjI3Y2M0ODhjYTE1YmRlZTEzZGY3MTM
[2025-01-20 19:39:43.994] [info] destroy: ts_chat_id=1
[2025-01-20 19:39:53.981] [info] TSBindingBrowserTSChat::create scHandlerId=0 server_identifier= specifier= endpoint=CENTRAL
[2025-01-20 19:39:53.982] [info] Save data path: server_identifier=chat-5.tmspk.net specifier=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 => C:\Users\Symo\AppData\Local\TeamSpeak\Cache\Default\tschat\Zjk4M2EyZmMwZjI3Y2M0ODhjYTE1YmRlZTEzZGY3MTM
[2025-01-20 19:39:53.982] [info] Matrix client create: matrixHost=chat-5.tmspk.net
[2025-01-20 19:39:53.987] [info] Created store from save data, loaded transactionId=1, searchDbSerial=0
[2025-01-20 19:39:53.987] [info] Init crypto storage
[2025-01-20 19:39:53.987] [info] created new group session storage
[2025-01-20 19:39:53.987] [warning] get key request data: unexpected end of JSON input
[2025-01-20 19:39:54.017] [info] connect: ts_chat_id=2 displayname=Symoaka presence=online
[2025-01-20 19:39:54.239] [info] Initial sync… nextBatch=
[2025-01-20 19:40:01.808] [info] TSBindingBrowserTSChat dtor
[2025-01-20 19:40:01.808] [warning] Failed to stop tschat connection on shutdown, err=1
[2025-01-20 19:40:01.808] [info] Save data path: server_identifier=chat-5.tmspk.net specifier=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 => C:\Users\Symo\AppData\Local\TeamSpeak\Cache\Default\tschat\Zjk4M2EyZmMwZjI3Y2M0ODhjYTE1YmRlZTEzZGY3MTM
[2025-01-20 19:40:14.382] [info] Initial sync failed: invalid status code: 503
[2025-01-20 19:40:14.382] [warning] TSChat_Connect failed: invalid status code: 503
[2025-01-20 19:40:14.382] [error] Connection failed: err=1
[2025-01-20 19:43:30.821] [info] TSBindingBrowserTSChat ctor
[2025-01-20 19:43:30.821] [info] TSChat library version: 1
[2025-01-20 19:43:32.913] [info] TSBindingBrowserTSChat::create scHandlerId=0 server_identifier= specifier= endpoint=CENTRAL
[2025-01-20 19:43:32.914] [info] Save data path: server_identifier=chat-5.tmspk.net specifier=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 => C:\Users\Symo\AppData\Local\TeamSpeak\Cache\Default\tschat\Zjk4M2EyZmMwZjI3Y2M0ODhjYTE1YmRlZTEzZGY3MTM
[2025-01-20 19:43:32.915] [info] Matrix client create: matrixHost=chat-5.tmspk.net
[2025-01-20 19:43:32.920] [info] Created store from save data, loaded transactionId=1, searchDbSerial=2
[2025-01-20 19:43:32.920] [info] Init crypto storage
[2025-01-20 19:43:32.921] [info] created new group session storage
[2025-01-20 19:43:32.921] [warning] get key request data: unexpected end of JSON input
[2025-01-20 19:43:32.977] [info] connect: ts_chat_id=1 displayname=Symoaka presence=online
[2025-01-20 19:43:33.321] [info] Initial sync… nextBatch=
[2025-01-20 19:44:23.494] [info] Initial sync failed: invalid status code: 504
[2025-01-20 19:44:23.494] [warning] TSChat_Connect failed: invalid status code: 504
[2025-01-20 19:44:23.494] [error] Connection failed: err=1
[2025-01-20 19:44:23.500] [info] stop: ts_chat_id=1
[2025-01-20 19:44:23.515] [info] Save data path: server_identifier=chat-5.tmspk.net specifier=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 => C:\Users\Symo\AppData\Local\TeamSpeak\Cache\Default\tschat\Zjk4M2EyZmMwZjI3Y2M0ODhjYTE1YmRlZTEzZGY3MTM
[2025-01-20 19:44:23.521] [info] destroy: ts_chat_id=1
[2025-01-20 19:44:33.512] [info] TSBindingBrowserTSChat::create scHandlerId=0 server_identifier= specifier= endpoint=CENTRAL
[2025-01-20 19:44:33.513] [info] Save data path: server_identifier=chat-5.tmspk.net specifier=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 => C:\Users\Symo\AppData\Local\TeamSpeak\Cache\Default\tschat\Zjk4M2EyZmMwZjI3Y2M0ODhjYTE1YmRlZTEzZGY3MTM
[2025-01-20 19:44:33.513] [info] Matrix client create: matrixHost=chat-5.tmspk.net
[2025-01-20 19:44:33.518] [info] Created store from save data, loaded transactionId=1, searchDbSerial=2
[2025-01-20 19:44:33.518] [info] Init crypto storage
[2025-01-20 19:44:33.518] [info] created new group session storage
[2025-01-20 19:44:33.518] [warning] get key request data: unexpected end of JSON input
[2025-01-20 19:44:33.526] [info] connect: ts_chat_id=2 displayname=Symoaka presence=online
[2025-01-20 19:44:33.756] [info] Initial sync… nextBatch=
[2025-01-20 19:45:48.526] [info] TSBindingBrowserTSChat ctor
[2025-01-20 19:45:48.526] [info] TSChat library version: 1
[2025-01-20 19:45:50.356] [info] TSBindingBrowserTSChat::create scHandlerId=0 server_identifier= specifier= endpoint=CENTRAL
[2025-01-20 19:45:50.357] [info] Save data path: server_identifier=chat-5.tmspk.net specifier=CiAvy1ibw3zwHk67lTmPwv5GJ9r1rONxd2JfZPvZB7xW5RKUAQpwzQMjrQkZ+mHz4zw2QtE1X9VKtqy4o7jF6S4SZpSS8ZBHB7QCcrOpQMoxIfpoAstHhJY7t8KKoICn5AstUzei7RMzn4B9bH4n1/PTIAFhNZamY7xLFVbjab7SHVl2i3MhneTNTgPkwZHXizlVH4ErdxIg2N6XzaolT9uKW8QGytptLkhW+aJS+5zPn5H3qJi6hVcYgICAgPCswq7yASIhAcNm67OO7p2R9TmO6wb08eW+h0vjbQe30nfnYXfvwqVDKrABuPQsmsx8RV59xg1ZyyaArZuIcp+xglPlYlneAFVey58tYF1sYaaDpO95Us3kMEFShcN6QeyO23TheEtqmuyHCwEA3lhpecKgocpIjyps49qcdJg3910Y2t8LsX7loEBdJsEAEs6mABjBWoAAAABCVGVhbVNwZWFrIFN5c3RlbXMgR21iSAAAI8Rq9g2zykckeBwWKLwIGGICCcXQTnP32eDHpZ00M5IGFqwJ9hbTM+4= => C:\Users\Symo\AppData\Local\TeamSpeak\Cache\Default\tschat\Zjk4M2EyZmMwZjI3Y2M0ODhjYTE1YmRlZTEzZGY3MTM
[2025-01-20 19:45:50.358] [info] Matrix client create: matrixHost=chat-5.tmspk.net
[2025-01-20 19:45:50.366] [info] Created store from save data, loaded transactionId=1, searchDbSerial=2
[2025-01-20 19:45:50.366] [info] Init crypto storage
[2025-01-20 19:45:50.366] [info] created new group session storage
[2025-01-20 19:45:50.366] [warning] get key request data: unexpected end of JSON input
[2025-01-20 19:45:50.383] [info] connect: ts_chat_id=1 displayname=Symoaka presence=online
[2025-01-20 19:45:50.683] [info] Initial sync… nextBatch=
[2025-01-20 19:46:40.897] [info] Initial sync failed: invalid status code: 504
[2025-01-20 19:46:40.897] [warning] TSChat_Connect failed: invalid status code: 504
[2025-01-20 19:46:40.897] [error] Connection failed: err=1
[2025-01-20 19:46:40.911] [info] stop: ts_chat_id=1
[2025-01-20 19:46:40.947] [info] Save data path: server_identifier=chat-5.tmspk.net specifier=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 => C:\Users\Symo\AppData\Local\TeamSpeak\Cache\Default\tschat\Zjk4M2EyZmMwZjI3Y2M0ODhjYTE1YmRlZTEzZGY3MTM
[2025-01-20 19:46:40.956] [info] destroy: ts_chat_id=1
[2025-01-20 19:46:50.935] [info] TSBindingBrowserTSChat::create scHandlerId=0 server_identifier= specifier= endpoint=CENTRAL
[2025-01-20 19:46:50.936] [info] Save data path: server_identifier=chat-5.tmspk.net specifier=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 => C:\Users\Symo\AppData\Local\TeamSpeak\Cache\Default\tschat\Zjk4M2EyZmMwZjI3Y2M0ODhjYTE1YmRlZTEzZGY3MTM
[2025-01-20 19:46:50.937] [info] Matrix client create: matrixHost=chat-5.tmspk.net
[2025-01-20 19:46:50.943] [info] Created store from save data, loaded transactionId=1, searchDbSerial=2
[2025-01-20 19:46:50.943] [info] Init crypto storage
[2025-01-20 19:46:50.943] [info] created new group session storage
[2025-01-20 19:46:50.943] [warning] get key request data: unexpected end of JSON input
[2025-01-20 19:46:50.955] [info] connect: ts_chat_id=2 displayname=Symoaka presence=online
[2025-01-20 19:46:51.206] [info] Initial sync… nextBatch=
[2025-01-20 19:48:01.397] [info] Initial sync failed: invalid status code: 504
[2025-01-20 19:48:01.397] [warning] TSChat_Connect failed: invalid status code: 504
[2025-01-20 19:48:01.397] [error] Connection failed: err=1
[2025-01-20 19:48:01.405] [info] stop: ts_chat_id=2
[2025-01-20 19:48:01.422] [info] Save data path: server_identifier=chat-5.tmspk.net specifier=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 => C:\Users\Symo\AppData\Local\TeamSpeak\Cache\Default\tschat\Zjk4M2EyZmMwZjI3Y2M0ODhjYTE1YmRlZTEzZGY3MTM
[2025-01-20 19:48:01.430] [info] destroy: ts_chat_id=2
[2025-01-20 19:48:21.430] [info] TSBindingBrowserTSChat::create scHandlerId=0 server_identifier= specifier= endpoint=CENTRAL
[2025-01-20 19:48:21.431] [info] Save data path: server_identifier=chat-5.tmspk.net specifier=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 => C:\Users\Symo\AppData\Local\TeamSpeak\Cache\Default\tschat\Zjk4M2EyZmMwZjI3Y2M0ODhjYTE1YmRlZTEzZGY3MTM
[2025-01-20 19:48:21.432] [info] Matrix client create: matrixHost=chat-5.tmspk.net
[2025-01-20 19:48:21.437] [info] Created store from save data, loaded transactionId=1, searchDbSerial=2
[2025-01-20 19:48:21.437] [info] Init crypto storage
[2025-01-20 19:48:21.437] [info] created new group session storage
[2025-01-20 19:48:21.437] [warning] get key request data: unexpected end of JSON input
[2025-01-20 19:48:21.452] [info] connect: ts_chat_id=3 displayname=Symoaka presence=online
[2025-01-20 19:48:21.684] [info] Initial sync… nextBatch=
[2025-01-20 19:48:45.058] [info] Initial sync failed: invalid status code: 502
[2025-01-20 19:48:45.058] [warning] TSChat_Connect failed: invalid status code: 502
[2025-01-20 19:48:45.058] [error] Connection failed: err=1
[2025-01-20 19:48:45.089] [info] stop: ts_chat_id=3
[2025-01-20 19:48:45.101] [info] Save data path: server_identifier=chat-5.tmspk.net specifier=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 => C:\Users\Symo\AppData\Local\TeamSpeak\Cache\Default\tschat\Zjk4M2EyZmMwZjI3Y2M0ODhjYTE1YmRlZTEzZGY3MTM
[2025-01-20 19:48:45.109] [info] destroy: ts_chat_id=3
Client Log:
[2025-01-20 19:45:48.526] [info] Notifications_Windows ctor
[2025-01-20 19:45:48.554] [info] TeamSpeak Client 5.0.0-beta77 (2023-12-12 11:58:52)
[2025-01-20 19:45:48.554] [info] SystemInformation: Windows 11 (26100) x64 (AMD or Intel) Binary: 64bit
[2025-01-20 19:45:48.903] [info] disconnected from push system.
[2025-01-20 19:45:50.353] [info] Initialized with 2 channels in 32bit, 48kHz. - Speakers (3- fifine Microphone)
[2025-01-20 19:46:13.972] [info] disconnected from push system.
[2025-01-20 19:46:18.537] [info] starting download for http://update.teamspeak.com/windows/x64/latest/info.json
[2025-01-20 19:46:18.973] [info] disconnected from push system.
[2025-01-20 19:46:23.981] [info] disconnected from push system.
[2025-01-20 19:46:28.993] [info] disconnected from push system.
[2025-01-20 19:46:34.001] [info] disconnected from push system.
[2025-01-20 19:46:39.013] [info] disconnected from push system.
[2025-01-20 19:46:44.018] [info] disconnected from push system.
[2025-01-20 19:46:49.019] [info] disconnected from push system.
[2025-01-20 19:46:54.027] [info] disconnected from push system.
[2025-01-20 19:46:59.042] [info] disconnected from push system.
[2025-01-20 19:47:04.043] [info] disconnected from push system.
[2025-01-20 19:47:09.048] [info] disconnected from push system.
[2025-01-20 19:47:14.056] [info] disconnected from push system.
[2025-01-20 19:47:19.066] [info] disconnected from push system.
[2025-01-20 19:47:24.079] [info] disconnected from push system.
[2025-01-20 19:47:29.088] [info] disconnected from push system.
[2025-01-20 19:47:34.089] [info] disconnected from push system.
[2025-01-20 19:47:39.090] [info] disconnected from push system.
[2025-01-20 19:47:44.098] [info] disconnected from push system.
[2025-01-20 19:47:49.101] [info] disconnected from push system.
[2025-01-20 19:47:54.103] [info] disconnected from push system.
[2025-01-20 19:47:57.805] [info] Initialized with 2 channels in 32bit, 48kHz. - Microphone (3- fifine Microphone)
[2025-01-20 19:47:57.810] [warning] Invalid identity on connect. Falling back to default identity.
[2025-01-20 19:47:57.810] [info] Connecting to free-dynip-hthwtr8saeqz.duckdns.org:50400
[2025-01-20 19:47:57.810] [info] Trying to resolve to free-dynip-hthwtr8saeqz.duckdns.org:50400
[2025-01-20 19:47:58.748] [info] A/AAAA DNS resolve for possible TSDNS successful, “free-dynip-hthwtr8saeqz.duckdns.org” =(h: 51.255.157.106 p:0)
[2025-01-20 19:47:58.749] [info] A/AAAA DNS resolve successful, “free-dynip-hthwtr8saeqz.duckdns.org” =(h: 51.255.157.106 p:0)
[2025-01-20 19:47:59.108] [info] disconnected from push system.
[2025-01-20 19:48:00.760] [info] TSDNS queried unsuccessfully 51.255.157.106:41144
[2025-01-20 19:48:00.760] [info] No TSDNS found
[2025-01-20 19:48:03.165] [info] SRV DNS resolve unsuccessful, “_ts3._udp.free-dynip-hthwtr8saeqz.duckdns.org” DNS server returned answer with no data
[2025-01-20 19:48:25.150] [info] disconnected from push system.
[2025-01-20 19:48:30.155] [info] disconnected from push system.
[2025-01-20 19:48:34.351] [info] SRV DNS resolve unsuccessful, “_tsdns._tcp.free-dynip-hthwtr8saeqz.duckdns.org” Timeout while contacting DNS servers
[2025-01-20 19:48:34.351] [info] Connecting to resolved address 51.255.157.106:50400
[2025-01-20 19:48:34.449] [info] server sent ciphers:1
[2025-01-20 19:48:34.541] [info] server sent ciphers:1
[2025-01-20 19:48:34.634] [info] server sent ciphers:1
[2025-01-20 19:48:35.163] [info] disconnected from push system.
[2025-01-20 19:48:40.172] [info] disconnected from push system.
[2025-01-20 19:48:45.181] [info] disconnected from push system.
[2025-01-20 19:48:50.195] [info] disconnected from push system.
[2025-01-20 19:48:55.205] [info] disconnected from push system.
[2025-01-20 19:49:00.213] [info] disconnected from push system.
[2025-01-20 19:49:05.225] [info] disconnected from push system.
[2025-01-20 19:49:10.234] [info] disconnected from push system.
[2025-01-20 19:49:15.238] [info] disconnected from push system.
I’m experiencing an issue with my TeamSpeak account where I cannot connect to the chat. I get an error stating that there is no internet connection. I created a new account and the chat works fine on it, so this seems to be an issue with TeamSpeak rather than on my side.
Here’s what I’ve noticed:
I also tried accessing tschat-2.teamspeak.com via a browser, but it shows a “Error 410” message, indicating that the link is permanently deleted.
Could anyone help me understand why this is happening and how I can fix it?
Thank you in advance for your help!
I installed Beta 5.0.0-beta77 yesterday and already had some problems with connecting to the messenger-servers. But today after updating to 6.0.0-beta2 i can’t even connect to them. It just tells me that i can’t connect to them and it tries again, but nothing happens.
Same by me. Trying to connect and after update messenger-servers kick me out with no reason. Reinstall, deletin’ cache and manipulation with router doing nothin’. Any ideas?
Hey both, thank you for the reports. We’re looking into it!
As you can imagine, there are a lot users trying to connect to the messenger at the same time, so please bear with us.
Thanks!
Same for me, thats the error from the logs:
[2025-01-21 22:45:04.019] [error] Check logins failed, abort login
(Since I don’t know how much personal data the logs contain, I keep them short and only post the error line.)
Tried cleaning cache, fully reinstalling the app, VPN (I thought that the server might be regionally blocked, but I guess not) nothing works, unless there’s something else to try.
My ts5client.log and tschat.log are here.
Hey, have the same issue have u got it fixed somehow?
same problem here
Try to run the application as an administrator
The .exe file is located in %localappdata%/Programs/Teamspeak folder
still the same
Hello. Please help me with connecting to your servers. I have an endless connection to the community servers. I don’t know what to do. I use TeamSpeak on my laptop and an Ethernet cable is connected to it and the Internet is working properly. But for some reason, the application has an endless network connection. Please help me solve this problem. Thank you in advance.
I also want to add that I use Windows 11. And another strange thing is that there is an endless connection to the servers, but at the same time I can safely use one of the public chats in the application. the sound is working, I can hear the guys in the voice channel and vice versa, they can hear me, but I can’t create my own server, most likely because of this stupid connection. Please help with this
Cant connect
TS Client Log
[2025-01-22 17:58:08.824] [info] Notifications_Windows ctor
[2025-01-22 17:58:08.850] [info] TeamSpeak Client 5.0.0-beta1 (2025-01-20 14:35:35)
[2025-01-22 17:58:08.850] [info] SystemInformation: Windows 11 (26100) x64 (AMD or Intel) Binary: 64bit
[2025-01-22 17:58:08.873] [warning] calling clientlib functions on uninitialized clientLib
[2025-01-22 17:58:13.328] [info] Initialized with 2 channels in 32bit, 48kHz. - Kulaklık İşitme Bölümü (HyperX Virtual Surround Sound)
[2025-01-22 17:58:31.508] [info] connected to push system.
[2025-01-22 17:58:31.508] [info] disconnected from push system.
[2025-01-22 17:58:36.517] [info] connected to push system.
[2025-01-22 17:58:36.517] [info] disconnected from push system.
[2025-01-22 17:58:38.832] [info] starting download for http://update.teamspeak.com/windows/x64/latest/info.json
[2025-01-22 17:58:40.078] [info] starting download for http://update.teamspeak.com/windows/x64/latest/1737383735-1737468425.patch
[2025-01-22 17:58:46.526] [info] connected to push system.
[2025-01-22 17:58:46.526] [info] disconnected from push system.
[2025-01-22 17:59:06.529] [info] connected to push system.
[2025-01-22 17:59:06.529] [info] disconnected from push system.
[2025-01-22 17:59:46.533] [info] connected to push system.
[2025-01-22 17:59:46.533] [info] disconnected from push system.
[2025-01-22 18:01:06.543] [info] connected to push system.
[2025-01-22 18:01:06.544] [info] disconnected from push system.
[2025-01-22 18:03:46.560] [info] connected to push system.
[2025-01-22 18:03:46.560] [info] disconnected from push system.
Hello, I have a problem with teamspeak 5/6
it shows me “unable to connect” for the homebase
1 - I used dev in the search to “clear” the homebase, it doesn’t change anything
2 - I reset my password, deleted teamspeak and all the folders in app data, nothing changes
3 - I put an old version of teamspeak 5 (beta 62) to use my TS for chat, impossible
4 - I changed my email, no change
5 - I put the code MULTIPASS but the code does not work
I’m out of ideas, I don’t know what to do, I’ve been looking for a solution on the forums for 2 hours :frowning:
i have the same issue
I guess the Homebase server is an official TeamSpeak server because the “Homebase project” was discontinued.
Try restarting your internet connection and PC, then try again.
I have the same problem and there is no reason for that. Of course I am connected to the internet!
