I have the problem that my microfon sometimes start cracking like ■■■■ when im talking. The problem is a ts3 problem only because in my stream my voice is clearly to hear. Im using a Rode NT1-USB Microfon. I also use Voicemeeter. I hope someone can help me with this problem.
Specs:
AMD Ryzen 7
RTX 2070
16 GB RAM
1000 GB HDD
240 GB SSD
Water Cooling System
I sometimes have the same problem using Voicemeeter. The problem is not with TeamSpeak but the VoiceMeeter audio cable drivers.
As I use Potato it is enough for me to switch between the output cables.
since i changed the input in teamspeak to Voicemeeter AUX Output (B2) and all other like stream to Voicemeeter VAIO Output (B1) there is no issue so i think that teamspeak have problems with shared souces?!
