microphone light always on
when joining ts microphone light is always on even if i’m not speaking
And have you tried to change Audio / Capture settings in client already or?
Maybe VAD and PTT are disabled?
Maybe Automatic mode doesn’t fit best for you.
vad is on and ptt is disabled
change to other mic it’s doesnt light up anymore
Is this solved? Or does it mean you no longer can talk at all?
no problem with talking only the light stays on
looks more like a visual bug because when i go on another server it doesn’t happen
Not impossible, but i have a doubt in that.
You can check if it’s just visual
When the lamp in system tray also lights up, then it is a sign that you are sending something trough the audio device. Could still be visual, but the next below would prove if you send something.
When you press the middle mouse button on yourself on server tree, then you get the connection info. When idle time stays 0 then you definitely send to the server.
When other user in same channel see you light up, then you definitely send to the channel.
other user can see it
yes my idle is standing on 0
and whenn i put vad on and of my mic is just normal
Turning off VAD and not having PTT enabled is expected to send continuously to the channel.
Is this solved or still a problem. I’m unable to read from your replies what status this
it is solved now
2 posts were merged into an existing topic: Can not save audio settings on non-default device since b65
