Microphone not working when in game
I’ve joined a server in TS and when I click out of the game the microphone works but I can’t hear anyone. When I click into the game and press my hotkey TS doesn’t register that it’s being pressed and it doesn’t work. I’ve checked the profiles and they’re all correct and the push to talk button is the same one I use when in game. I’m stumped as I need to use TS at the same time as the game. Anyone any clues or solutions?
Which operating system do you use?
Windows 11
Does this happen with every game? Or just one game in particular?
I only use TS when I’m playing the one game so as far as I can tell it’s this game
Do you use any third party tools which could override the hotkeys? Can you show your Bookmark settings, to verify that the profile is correclty set?
I don’t have any third party tools - this is the only one
How does your Bookmark settings look like? (CTRL + B)
Sorry I’m not the technically smartest person :joy:
When you click on Go Advanced it should say Always default for the hotkey profile right?
It just says default, should I switch it to “Always Default” ?
Yeah you can try that and when connecting to the server you need to do it trough the Bookmarks tab.
Just switched and tested and it’s still not working sadly
Does the server has any advises on how to set up your client for RP?
