Here are the latest system requirements.
Some may need or use that information ![]()
TeamSpeak 3 Server
Windows
Windows 8.1 and newer, 32- and 64-bit
Mac OS X
Mac OS X 10.9 and above, 32- und 64-bit Intel CPU
Linux
Any recent Linux distribution, 32- and 64-bit
FreeBSD
10.2 and above, 32- and 64-bit
CPU
SSE2 capable CPU
SSE4.x capable CPU with POPCNT enabled (Only for the 64-bit version on Windows)
Memory
Depending on operating system, minimum 1 GB RAM recommended.
Total memory usage depends on number and size of hosted virtual servers.
Hard disk
Bare minimum installation 15 MB.
Total disk usage is highly dependent on actual usage, size and amount of hosted virtual servers.
Additional space required for file transfer and icon/avatar storage.
TeamSpeak 3 Client
Windows
Windows 8.1, 10 and newer, 32- and 64-bit
Mac OS X
Mac OS X 10.9 and above, 64-bit Intel CPU
Linux
Any recent Linux distribution with libstdc++ 6, 32- and 64-bit
CPU
SSE2 capable CPU
Memory
The TeamSpeak Client requires around 20-60 MB RAM, depending on the number and size of the currently connected servers.
Minimum 1 GB RAM recommended. Some operating system may require more RAM to run properly.
Hard disk
60-100 MB free (depending on operating system)
TeamSpeak Client version 5
Only 64-bit operation systems are supported.
The system requirements are not final yet but should match the rest from the TS3 client.
Mobile TeamSpeak 3 Client
Android
Android 4.2 and above, ARM v7 CPU
Google Play Store support
iOS
iOS 7.1 and above
Minimum iPhone 4 / iPad 2 / iPod Touch 5th generation
ARM CPUs are not supported for server and PC Client.
Please don’t ask the support for help in case something isn’t working as intended.
