I have licenses for 64 slots, but when more then 6-10 people join, its packet loss city. Please help.
how’s the bandwidth of your server
root@152:~# ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 132.148.78.152 netmask 255.255.255.255 broadcast 0.0.0.0
inet6 fe80::5054:24ff:fe0d:7296 prefixlen 64 scopeid 0x20
ether 52:54:24:0d:72:96 txqueuelen 1000 (Ethernet)
RX packets 2595857 bytes 864458473 (864.4 MB)
RX errors 0 dropped 1 overruns 0 frame 0
TX packets 7209587 bytes 1362183024 (1.3 GB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10
loop txqueuelen 1000 (Local Loopback)
RX packets 38484447 bytes 20444270608 (20.4 GB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 38484447 bytes 20444270608 (20.4 GB)
i mean your server spec
What is the maximum bandwidth of your server?
No clue, I have no idea where to find that information from godaddy.
I think you should check your server or the connection with your server.
The avenage number of my server is almost over 20, and I have never face that problem.
P.S. when I put a teamspeak on a 1Mpbs Bandwidth server, the maximun connection would be like 10 people.
Ya, I haven’t been able to find that information. I’ve been in contact with godaddy and they had me to a server reboot and said that should fix it. Im waiting till we have another group on to see if its fixed.
