My computer seems to be blocking myteamspeak. I have scoured the internet, Reddit, and the official forums and cant seem to find any info.
When I got to tools and options on teamspeak 3 this is when pops up:
I have no interest in using My-Teamspeak but I figured why not try it to attempt to fix the issue of this annoying popup. When i click “do not show again”… it does show again, so I am forced to see this prompt every time I go to the settings.
I can login to https://www.myteamspeak.com with no issues.
The following quote is what shows when I open teamspeak 3. (Notice the warning)
Blockquote 5/18/20 06:00:57 Info TeamSpeak Client 3.5.3 (2020-05-06 09:07:50)
5/18/20 06:00:57 Info SystemInformation: Windows 10 (18362) x64 (AMD or Intel) Binary: 64bit
5/18/20 06:00:57 Info Using hardware aes
5/18/20 06:00:57 Direct Sound Debug setting timer resolution to 1ms -
5/18/20 06:00:58 ClientUI Info OpenGL Info: LibGLES, Vendor: Google Inc., Renderer: ANGLE (NVIDIA GeForce GTX 950 Direct3D11 vs_5_0 ps_5_0), Version: OpenGL ES 2.0 (ANGLE 2.1.0.57ea533f79a7)
5/18/20 06:00:58 Info *** Time [ICONMANGER]: 180
5/18/20 06:00:58 Addons Info Checking for addon updates…
5/18/20 06:00:58 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
5/18/20 06:00:58 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
5/18/20 06:00:58 ProtobufRPC Warning Server at URL https://clientapi.myteamspeak.com/addon responded: 403 Forbidden
5/18/20 06:00:58 Info failed to load static integration list
5/18/20 06:00:58 Info *** Time [BUILD_GUI]: 599
5/18/20 06:00:58 Info *** Time [SERVERVIEW]: 632
5/18/20 06:00:59 Info *** Time [SERVERVIEWMANAGER]: 650
5/18/20 06:00:59 Info *** Time [MAINWINDOW]: 1137
5/18/20 06:00:59 Info *** Time [INIT]: 1137
5/18/20 06:00:59 ClientUI Info Qt version: 5.12.3
5/18/20 06:00:59 ClientUI Info Using configuration location: C:\Users\Davis\AppData\Roaming\TS3Client\settings.db
5/18/20 06:00:59 ClientUI Info Last update check was: Mon May 18 00:37:31 2020
5/18/20 06:00:59 Info Statistics report: Not yet, next report on Sat Jun 6 00:41:29 2020
5/18/20 06:00:59 Bookmarks Info Collecting autoconnect bookmarks
5/18/20 06:01:00 Newsticker Info Newsticker next check: Tue May 19 05:37:25 2020 GMT
I have tried disabling firewall and windows defender and it doesn’t do anything. I have tried 3.5.3 and 3.5.2 and both don’t work.
I acquired the beta install of ts5 and tried to login on there but it would not login. I click login and nothing happens.
Something is not allowing myteamspeak to communicate.
