i have this error:
08.03.2021 18:25:26 SoundBckndIntf Error C:/Program Files/TeamSpeak 3 Client/soundbackends/windowsaudiosession_win64.dll error: GETTING_PROPERTY_VAR_NAME
have you tried to Manuel Select the Microphone,
I´ve read that it is trying to autoselect the Microphone.
Make sure you have the latest client, drivers and Windows updates installed.
Good afternoon, Today I entered teamspeak and noticed that I couldn’t speak because my microphone was not being detected by TeamSpeak, in several other apps it works normally.
Hi, please read or show the client log. There you can see why it faulted.
Blockquote23/01/2023 15:08:50 Info TeamSpeak Client 3.5.6 (2020-11-25 13:53:42)
23/01/2023 15:08:50 Info SystemInformation: Windows 10 (22621) x64 (AMD or Intel) Binary: 64bit
23/01/2023 15:08:50 Info Using hardware aes
23/01/2023 15:08:50 Direct Sound Debug setting timer resolution to 1ms -
23/01/2023 15:08:50 SoundBckndIntf Error C:/Program Files/TeamSpeak 3 Client/soundbackends/windowsaudiosession_win64.dll error: GETTING_PROPERTY_VAR_NAME
23/01/2023 15:08:50 ClientUI Info OpenGL Info: LibGLES, Vendor: Google Inc., Renderer: ANGLE (NVIDIA GeForce RTX 3060 Ti Direct3D11 vs_5_0 ps_5_0), Version: OpenGL ES 2.0 (ANGLE 2.1.0.57ea533f79a7)
23/01/2023 15:08:50 Addons Info Checking for addon updates…
23/01/2023 15:08:50 Plugins Info Loading plugin: teamspeak_control_plugin_win64.dll
23/01/2023 15:08:50 ControlPlugin Info Control Plugin started, accepting connections
23/01/2023 15:08:50 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
23/01/2023 15:08:50 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
23/01/2023 15:08:50 Addon Info Addon up to date.
23/01/2023 15:08:50 Info *** Time [BUILD_GUI]: 257
23/01/2023 15:08:50 Info *** Time [SERVERVIEW]: 272
23/01/2023 15:08:50 Info *** Time [SERVERVIEWMANAGER]: 277
23/01/2023 15:08:50 Info *** Time [MAINWINDOW]: 527
23/01/2023 15:08:50 Info *** Time [INIT]: 527
23/01/2023 15:08:50 ClientUI Info Qt version: 5.12.3
23/01/2023 15:08:50 ClientUI Info Using configuration location: C:\Users\diogo\AppData\Roaming\TS3Client\settings.db
23/01/2023 15:08:51 Bookmarks Info Collecting autoconnect bookmarks
23/01/2023 15:08:51 ClientUI Info Last update check was: seg jan 23 14:56:27 2023
23/01/2023 15:08:51 Info Statistics report: Not yet, next report on sex jan 27 14:57:58 2023
23/01/2023 15:08:51 Newsticker Info Newsticker language change detected
23/01/2023 15:08:51 Newsticker Info Newsticker next check:
23/01/2023 15:08:52 Newsticker Info Newsticker received for language en, expires on ter jan 24 15:08:52 2023 GMT, next check in 86399 seconds
23/01/2023 15:08:53 ClientUI Info Connect to server: ts.replaytuga.com
23/01/2023 15:08:53 ClientUI Info Trying to resolve ts.replaytuga.com
23/01/2023 15:08:53 TSDNS Info SRV DNS resolve unsuccessful, “_tsdns._tcp.replaytuga.com” Domain name not found
23/01/2023 15:08:53 TSDNS Info SRV DNS resolve successful, “_ts3._udp.ts.replaytuga.com” =(h: ts.replaytuga.com p:9987)
23/01/2023 15:08:53 TSDNS Info A/AAAA DNS resolve successful, “ts.replaytuga.com” =(h: 54.38.187.46 p:0)
23/01/2023 15:08:53 TSDNS Info A/AAAA DNS resolve for possible TSDNS successful, “ts.replaytuga.com” =(h: 54.38.187.46 p:0)
23/01/2023 15:08:53 ClientUI Info Lookup finished: ip=54.38.187.46 port=9987 query=ts.replaytuga.com error=0
23/01/2023 15:08:53 ClientUI Info Resolve successful: 54.38.187.46:9987
23/01/2023 15:08:53 ClientUI Info Initiating connection: 54.38.187.46:9987
23/01/2023 15:08:53 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
23/01/2023 15:08:53 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
23/01/2023 15:08:53 Windows Audio Session Debug WAS::openDevice-enter - {0.0.0.00000000}.{c0bc4759-2d02-4b1d-8ab9-d6bd4e86c9ef}
23/01/2023 15:08:53 TSDNS Info A/AAAA DNS resolve for possible TSDNS successful, “replaytuga.com” =(h: 104.21.81.93 p:0)
23/01/2023 15:08:53 Windows Audio Session Devel Mix Format: SRate:48000 Bitrate: 32 Channels: 2 - Auricular (HyperX Virtual Surround Sound)
23/01/2023 15:08:53 Windows Audio Session Devel Initializing with mix format. - Auricular (HyperX Virtual Surround Sound)
23/01/2023 15:08:53 Windows Audio Session Info Initialized with 2 channels in 32bit, 48kHz. - Auricular (HyperX Virtual Surround Sound)
23/01/2023 15:08:53 Windows Audio Session Devel WAS Buffer size: 1056 - Auricular (HyperX Virtual Surround Sound)
23/01/2023 15:08:53 Windows Audio Session Debug WAS::openDevice-leave - {0.0.0.00000000}.{c0bc4759-2d02-4b1d-8ab9-d6bd4e86c9ef}
23/01/2023 15:08:53 Windows Audio Session Debug WAS::startDevice-enter - {0.0.0.00000000}.{c0bc4759-2d02-4b1d-8ab9-d6bd4e86c9ef}
23/01/2023 15:08:53 Windows Audio Session Debug WAS::startDevice-leave - {0.0.0.00000000}.{c0bc4759-2d02-4b1d-8ab9-d6bd4e86c9ef}
23/01/2023 15:08:53 ClientUI Info Connect status: Connecting
23/01/2023 15:08:53 PktHandler Devel Puzzle solve time: 7
23/01/2023 15:08:54 ClientUI Info Connect status: Connected
23/01/2023 15:08:54 ClientUI Info Connect status: Establishing connection
23/01/2023 15:08:54 ClientUI Info Connect status: Connection established
23/01/2023 15:08:55 TSDNS Info TSDNS queried unsuccessfully 54.38.187.46:41144
23/01/2023 15:08:55 TSDNS Info No TSDNS found
23/01/2023 15:08:55 TSDNS Info TSDNS queried unsuccessfully 104.21.81.93:41144
23/01/2023 15:09:06 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
23/01/2023 15:09:06 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
23/01/2023 15:09:06 CapSoundSet Error Failed to open capture device when updating capture system: 2321
23/01/2023 15:09:06 CapSoundSet Error Error setting PreProcessorConfigValues when updating capture system: aec to false: 2304
23/01/2023 15:09:06 CapSoundSet Error Error setting PreProcessorConfigValues when updating capture system: agc to true: 2304
23/01/2023 15:09:06 CapSoundSet Error Error setting PreProcessorConfigValues when updating capture system: denoise to true: 2304
23/01/2023 15:09:06 CapSoundSet Error Error setting PreProcessorConfigValues when updating capture system: denoiser_level to 1: 2304
23/01/2023 15:09:06 CapSoundSet Error Error setting PreProcessorConfigValues when updating capture system: typing_suppression to false: 2304
23/01/2023 15:09:06 CapSoundSet Error Error setting PreProcessorConfigValues when updating capture system: vad to true: 2304
23/01/2023 15:09:06 CapSoundSet Error Error setting PreProcessorConfigValues when updating capture system: vad_extrabuffersize to 1: 2304
23/01/2023 15:09:06 CapSoundSet Error Error setting PreProcessorConfigValues when updating capture system: vad_mode to 0: 2304
23/01/2023 15:09:06 CapSoundSet Error Error setting PreProcessorConfigValues when updating capture system: vad_rnn to true: 2304
23/01/2023 15:09:06 CapSoundSet Error Error setting PreProcessorConfigValues when updating capture system: voiceactivation_level to -40: 2304
23/01/2023 15:12:45 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
23/01/2023 15:12:45 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
23/01/2023 15:12:45 CapSoundSet Info Could not reactivate capture device after VAD voice test: 1799
The client (the dll we use) fails to read the values coming from your device.
Make sure your drivers are up to date.
Also can you please update the client to beta 3.6.0 ?
