MyTeamspeak login dont work
Hey, i cant login in my Myteamspeak account in ts3 Client. On the Myteamspeak Website it work.
Log :
24.04.2020 14:07:39 SCHandler Info try to delete mytsid while no valid mytsid is set - abort
24.04.2020 14:07:42 ProtobufRPC Warning Error contacting URL https://clientapi.myteamspeak.com/authentication: SSL_ERROR: Alert on protocol: TLS 1.2 level: fatal error: unsupported_certificate (43)
24.04.2020 14:07:42 ClientUI Warning Account login failed, server currently not available. Retry in few minutes.
Trying for some days now. But never Work. Email and Passwort is right.
Sync is enabled
MITM Attack on the TLS Connection, probably caused by your Antivirus. Disable HTTPS sniffing.
and how. I dont know what this is. Sorry. i Disabled my antivirus but it still dont work
What have you for a Antivirus and have you tried to deactivate your Firewall?
Gdata, and yes. Deactivatet firewall but still error
What OS are you using?
(There are some TLS 1.2 problems in some Windows versions)
This is the article I referred to last time:
