Need help to start ts3 with new license key. Debian
how to start ts3 cloud server at debian linux? Just send license key to server
Have you started the server before or do you need help starting the server for the first time?
server has be up before, but i think that i have to start it again
our it man died and i do not know to start it. Ts3 client do not connect
I am sorry for that.
To get the license up and running:
  1. Place the licensekey.dat file on the root directory of your TeamSpeak 3 Server installation folder.
  2. Stop & restart the TeamSpeak 3 Server master binary (exe) process.
Once that is done, you can check the logs of the server and see if the license is correctly validated.
If the license is correctly applied you then should be able to adjust the slot count of the virtual server.
