I set my server up with the following guest permission:
i_channel_subscribe_power = -1
So everytime a temporary channel is created, guests can’t see who’s in there. My problem now is that everytime someone creates a channel, all other guests hear a “insufficient permissions” with the following message:
insufficient client permissions (failed on i_channel_needed_subscribe_power)
The teamspeak server also has a similiar configuration (you cant see who is in which channel) but the problem doesn’t exist there. Does anyone know how the public server might be configured?
No, it isn’t. Because I don’t want to fix the problem by giving guests all permissions to see who is in other channels. Besides, setting “i_client_max_channel_subscriptions” to -1 works perfectly fine.
That is the same configuration as mine. Can you join your server with a guest identity and create a temp channel as the admin? Do you hear “insufficient permissions”? What server version do you use?
Or even better: Can you give me your server address so I could check it myself?
