Hi there,
with the new TS6 Update there are some changes made in the style files.
Can someone tell me how to change the colors of the areas i marked with the numbers?
This would be so helpful for me. I already tried for hours…
1 = Background of Mic/Speaker Button
2 = Channel Background (Light Blue)
3 = Channel Tree Background (Black to White)
4 = Channel [cspacer] Background (Black to White)
5 = Connection Quality Indicator Background
6 = not on the PIC: Background of the Connection Overlay (white transparent)
do someone found out how to change that?
I have updated my theme to work with the latest version, so if you need to adjust anything, you can see if that helps you:
Thank you for your answer. But in your theme is the channel backgroundcolor not changed. Do you know where i can find this color to change it?
Not sure right now, I’ve disabled the setting that shows channel backgrounds. But i could check tomorrow if you still need that.
that would be cool. I already found some nice settings in your css files. That already helped me a lot
For the Channel background you’ll need to set a background to this CSS class:
.ts-server-tree-item-background-no-image {
background: linear-gradient(to right, #17191c 50%, #1e1e1e 100%) !important;
thank you so much.
Do you maybe have information about how to change the channel background color if it is highlighted? I think this would be the last thing i have to change to be absolutely happy
.ts-server-tree-item-leaf.channel:not(.spacer) .ts-server-tree-item-background-no-image+.tsv-item-highlight {
background: linear-gradient(to right, var(--custom-color-accent-dark) 0%, var(--custom-value-dark5) 40%,var(--custom-value-dark5) 100%) !important;
This code does however not 100% work, as it also styles channels when they are full or password protected. I don’t see a solution to only select it to the selected channel.
thanks for your help. I really appreciate that! I try it later when i have more time to test it and i will give you feedback
this one isn’t working for me. I tried it like you and i tried with color codes directly:
background: linear-gradient(to right, #6d1f32 0%, #6d1f32 40%, #6d1f32 100%);
The Channel Hover Background is still blue
Whoops forgot the !important
Edited my post
thank you soooo much for your help
@LeonMarcelHD
By the way: This is how my design look at the moment. It is based on your Colorful Teamspeak Theme - Pink
