Need to change ip
In the server list i can see my server but its connected to a diffrent ip cuz im in a new house and the server ip is my old house ip so yeah i want it to be changed can someone help me with that
Weblist listing will change automatically, if your server have enabled reporting.
What do you mean?
i have it enabled and the ip doesnt change
The list updates every ~10 - 11 minutes and whatever IP your server finds first is reported there.
To change your IP there you must own/use another IP. Contact your ISP or Admin or whoever has Access to change your own IP.
but i have waited more than ~ 10 - 11 minutes and its detecting only public ip but the server gets created in private ip
i meant that server only uses private but in the server list it uses public
how do i even report my server to the weblist?
it’s enabled but its not updating the server is up for 3 hours 19 minutes
i always remember that
Again, weblist shows the address from which your server contacting it.
It simply can not be your private IP. Network just does not work that way.
well i could change my server ip to that but i dont know how to cuz when i google that it doesnt work
great ip changed still cant enter that through server list
no it changed to my new public ip cuz i got a new router
but still cant enter trough the server list
only client stuff
i just port forwarded and then what is there a way i could change server ip
honestly i should give up
