Network driver results in constant timeouts
Hello, I do not know if this is the right place to ask, but I have a problem with TS3.
I am trying to connect to a server, which at first seems to succeed, but within a minute TS3 says connection lost and I am thrown out of the server.
TS3 connects again and again looses connection Thie repeats itself every minut.
in the bottom there is a message about; if you keep having errors with TS3 32 bit please try 64 bit. I can’t understand why it says that because I have downloaded the 64 bit version which is, as far as i can see, the only version to be downloaded. Have it installed several times now. Also tried TS5(?) made an account for it and have the same problems.
In a log I found about the session is this:
[2025-03-29 17:05:11.766] [info] Notifications_Windows ctor
[2025-03-29 17:05:11.779] [info] TeamSpeak Client 6.0.0-beta2 (2025-01-21 14:07:05)
[2025-03-29 17:05:11.779] [info] SystemInformation: Windows 11 (26100) x64 (AMD or Intel) Binary: 64bit
[2025-03-29 17:05:11.787] [warning] calling clientlib functions on uninitialized clientLib
[2025-03-29 17:05:12.120] [info] successfully downloaded revocation list for accounting
[2025-03-29 17:05:12.243] [info] successfully downloaded revocation list for myteamspeak id
[2025-03-29 17:05:14.117] [info] Initialized with 2 channels in 32bit, 48kHz. - Hoofdtelefoon (Oculus Virtual Audio Device)
[2025-03-29 17:05:30.292] [info] Notifications_Windows dtor
[2025-03-29 17:05:50.421] [info] Notifications_Windows ctor
[2025-03-29 17:05:50.435] [info] TeamSpeak Client 6.0.0-beta2 (2025-01-21 14:07:05)
[2025-03-29 17:05:50.435] [info] SystemInformation: Windows 11 (26100) x64 (AMD or Intel) Binary: 64bit
[2025-03-29 17:05:50.443] [warning] calling clientlib functions on uninitialized clientLib
[2025-03-29 17:05:52.538] [info] Initialized with 2 channels in 32bit, 48kHz. - Hoofdtelefoon (Oculus Virtual Audio Device)
[2025-03-29 17:06:20.426] [info] starting download for http://update.teamspeak.com/windows/x64/latest/info.json
[2025-03-29 17:09:21.428] [error] File validation failed for images/presets/banner12.png, expected f6c248784413ad22dbb50b48f59d4a5ae8485bade7fc8939f7a6fea232b9591f177afde83825e69ecb5a1c2742c59afe8a32e3956be4aec8e681a8236b8c0af3 got
[2025-03-29 17:09:21.428] [error] File validation failed for images/presets/banner2.png, expected ad97e8239f7988b5fb522c99d989bc4f42df9beb84428d23797041986a8f684cd178aafc09596b0b2f6db737f41232c26bc5378c058533f1c5e4e9e239a45574 got
[2025-03-29 17:09:21.429] [error] File validation failed for images/presets/banner14.png, expected 5c8b809d260d2a14286f88447fcb1ba0ed46cac8f17619859ddb5e67397c2a007855065572c39ad0ff0b83582fa6b1becd4726d3a08ce5275b6e0f3b54e15e88 got
[2025-03-29 17:09:21.429] [error] File validation failed for images/presets/banner9.png, expected 9aee35b796b00feacd06c6ec6e150a3992c8084e9028115c62dfa2436f0b497e5016410f2be212da30983c3b4dbd4b97b22fce682578b0bb0601715ae1b9233d got
[2025-03-29 17:09:21.430] [error] File validation failed for images/presets/banner20.png, expected 694aad81ac22455c993f7ccfce77f6a6c13b450246c5e488194e95fb217522a82841d844041e4d49154c545ca4a54ed7dbd3c6003136d3458ed2341c990ad957 got
[2025-03-29 17:09:21.430] [error] File validation failed for images/presets/banner17.png, expected e5f1bd9f7423a7a7ab83167f94e7c2f4e0238e3594358f640ff5e2c47f1712a963a667f96fce93dfa73c2d868a96e4e754da0d61858a60993c5df814a2ebff04 got
[2025-03-29 17:09:21.430] [error] File validation failed for images/presets/banner16.png, expected 59484de2f10d20be8d77daad0cc4f2821b6104b2878753593b3e67f198dce102ed720780f73b3bdc684b999f881c114d4a3d8383de6c9adf15bb14336c63edd9 got
[2025-03-29 17:09:21.430] [error] File validation failed for images/presets/banner26.png, expected 03c79fece4b4491397a18bcf813ced2a2e89a4d88eaee749c470b2eed02436cef3e9b0e62b51e1a3f293a57374119ae5863f971ff4fdaef837c37ed54b77c6ca got
[2025-03-29 17:09:21.456] [error] File validation failed for images/presets/banner12.png, expected f6c248784413ad22dbb50b48f59d4a5ae8485bade7fc8939f7a6fea232b9591f177afde83825e69ecb5a1c2742c59afe8a32e3956be4aec8e681a8236b8c0af3 got
[2025-03-29 17:09:21.456] [error] File validation failed for images/presets/banner2.png, expected ad97e8239f7988b5fb522c99d989bc4f42df9beb84428d23797041986a8f684cd178aafc09596b0b2f6db737f41232c26bc5378c058533f1c5e4e9e239a45574 got
[2025-03-29 17:09:24.573] [info] Notifications_Windows dtor
I have no idea what is meant in this log.
Does someone know what is going wrong here?
Thanks
  1. List item
The attached log is from TS6.
Have you tried using a different server? (for example the servers linked on the TS6 dashboard)
Do you friends have also connection problems?
O, I am sorry didn’t know that. Can’t find a log in the ts3 folder in appdata.
I must have tried ts6 then instead of 5, but as i said i had the same problems, disconnecting and connecting every minute.
I do not know of someone who is also experiencing problems with this server.
I did not try other servers, the problems i Have are on a new pc I am using now. My old pc is also a win11 pc and i have never experienced problems connecting. I have it still working and just tried connecting to the server and it is still on, no problem at all,
TS5 is now TS6. It had a major version change with the latest screen share release.
How are both computers connected to the internet? Via LAN or WiFi
Wifi,
I just installed teamspeak from windows store.
My old pc is still connected, this pc disconnected within a minute.
There is a message in this app that says
Too many clones already connected.
and i am banned from the server now
It says flood prevention try later
For flooding I guess right? You’ve then had too many actions in the last few minutes.
So both are connected with WiFi, if so try to move with the one closer to your router. It may be possible that your old computer has a stronger network card / onboard WiFi.
I am sorry both are on a cable internet is 1000 up and 1000 down. ping is low. 4ms?
Also pinged the server in cmd and that was +/- 30ms
That seems okay I tried it several times in a row always the same
Can you please send the latest log where the client disconnects?
And to be sure you are getting disconnected from the TeamSpeak server and not the chat on the left sidebar right?
I can not find any log in appdata for ts3
I attached two pictures of the server and what is happening, you can see the server is not loading completly every time,
Also the timestamps are about every minute
Can you do a speedtest of your internet on that computer?
The server is working fine for me and the problem has to be somewhere on your (local) network.
Thanks Leon, for helping me.
I had this problem from wednesday, so yesterday after all the struggle I was not in the mood to go for a further search. But the answers you gave made me thinking. The pc is only a week old and I just turned wifi of because I was on a cable. Today I tried to go in the teamspeak server with wifi on and cable out. Everything suddenly worked fine. I then plugged the cable back in while ts still was on and it stayed working fine. Turned of teamspeak and opened it again, problem was there again.
Tried to update the network controller then but it was on the right software working fine according to windows. I then deleted the network controller and completly deinstalled it in device manager. Started the pc again and now it s working as it should.
So very happy its solved, thanks again
