Good evening, I have a problem with Teamspeak for Android, namely on Teamspeak others on the server that I share with others see a different name than I see it on my display, namely the name Adolf Hitler, although I haven’t changed anything great . We had dealt with a hacker in the past few days.
What do you expect from us?
Rename (you or owner) the server back to it’s original name?
Develop an update that will prevent such manipulations in the future.
There is no way for others to change your nickname except if he has access to you Account and can change your Identitiy name (or Bookmark username)
Or if it is the Server name, you need to make sure that the permissions are all set correctly and don’t give random users permission to change it.
understand. I set up my account again and on Teamspeak I was able to speak to others for a short time without any disturbances in the signal chain.
However, the problem has returned.
And the problem now is exactly what?
You have to change the name again yourself. TeamSpeak has no access to it.
